'68 - 70 B body vent window anti rattle spacer?
#955610
03/21/11 04:16 PM
03/21/11 04:16 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Anybody know where to get (or even what they look like) the "anti rattle spacers" that go over the pin inside the bottom of the door to hold/locate the vent window frame?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: '68 - 70 B body vent window anti rattle spacer?
[Re: DPelletier]
#955615
03/22/11 01:02 PM
03/22/11 01:02 PM
DPelletier
Thanks guys; I have 4 doors and none of them have anything on that pin. The parts manual calls up a "anti rattle spacer" or something like that, but I had never seen one. My guy that's helping me insists that there should be a bushing or something that can be supply upwards pressure to the vent frame to keep in in place as the other two bolts appear inadequate to the task, but I told him I had my doubts and that if there was a bushing, it wouldn't have been called an "anti rattle spacer", it would have been called a bushing, spring or spacer. sounds like that pin just provides a locate and doesn't push up on the vent frame at all. Dave
1974 'Cuda
[Re: DPelletier]
#955616
03/22/11 11:33 PM
03/22/11 11:33 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I have found that the pin is just for glass tilt adjustment for a tighter fit to the door frame . I have found many of cars with them broke off the frame and window worked ok . the cars i have had three b bodys all had them broken off and sitting at the bottom of the door and when i restore them i welded the part back on to the window vent channel run never used any type of bushing and never heard or had one rattle yett . not saying it wont just do see it to be much of a problem to worrie about , my fuel pump is louder than most rice burners out there HA HA.
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#955617
03/23/11 12:21 PM
03/23/11 12:21 PM
DPelletier
That's what my buddy is saying; that the pin pushes up to tilt the vent frame for a tighter fit to the door frame, but it can't do that unless there is something to give it upwards pressure right? without any sort of bushing, the vent frame is free to float on the pin with no upwards pressure.
I'm convinced that there was no such bushing, but without one, you are relying on the two upper bolts to hold the vent frame in position, correct?
1974 'Cuda
[Re: 70mopes]
#955618
03/23/11 02:48 PM
03/23/11 02:48 PM
Posts: 1,106 CANADA
Desmond
CANADA
Oh.... Was thinking of something else. This is what you are referring to. This is a shot of an original installation.
That is so lame.
[Re: DPelletier]
#955619
03/24/11 12:41 AM
03/24/11 12:41 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
I just looked in my old door that come off my GTX. That pin does NOT put upwards pressure on the channel.....it adjusts in and out in a slot in the bottom of the door to keep the lower portion of the track in the proper relation to the top section that bolts to the door.Without that pin holding the channel it could "wander" around when the glass is rolled down. The "sponge" just keeps it snug in the channel bracket. It does help with the alignment of the whole vent channel. but only in and out.
[Re: DPelletier]
#955620
03/24/11 01:30 AM
03/24/11 01:30 AM
Posts: 2,483 Minneapolis, MN
hemi70se
Minneapolis, MN
There are 3 bolts that hold the vent frame in place.... the 2 9/16s bolts under the plastic caps and the allen head bolt under the tiny plug. The white foam insert is the correct way the factory did them.
[Re: SixPackRT]
#955623
03/24/11 01:40 PM
03/24/11 01:40 PM
DPelletier
[quote Is this for your Bee I thought your windows were all in? Scott
Thanks guys. Yeah, it's for the Bee and all the windows are in with the exception of the 1/4 windows. I thought all I needed to do was add a couple missing rods to the door latches, but it turned into a complete teardown and reworking of all the door components!
1974 'Cuda
