Trans Question
#953758
03/19/11 03:14 PM
03/19/11 03:14 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey guys, I have a question if you could answer it. I just went to a 727 race transmission with a ton of aftermarket parts in it I drove it around the block and shifts fine. The problem I have is It seems a little soft shifting into 2nd gear. No slip at all and I have adjusted the front band. The transmission shifts real hard into 3rd gear but it just feels a little soft into 2nd. This is a old Turbo Action Manual valve body. I have not really shifted it under full power yet. It does have a pretty high 8" stall in it about 5500. Any ideas ?
6.50 @105.26
Re: Trans Question
[Re: Cab_Burge]
#953760
03/19/11 03:52 PM
03/19/11 03:52 PM
Kindafast
Seaford, Va
Thanks Cab , The shifter is adjusted right , it's right on the money with the detent on the shifter. The trans shifts pretty hard into 3rd gear no matter what rpm I am at. I am hoping it's not hanging up on 2nd gear like you said. I will take it back out and hit it and see what it does from there. I will let you know . Thanks,
6.50 @105.26
Re: Trans Question
[Re: Kindafast]
#953761
03/19/11 07:05 PM
03/19/11 07:05 PM
Posts: 2,047 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
If the transmission is "right", with that valve body, you will feel the trans shift before you feel the shifter "click". When on jackstands, you most likly WON'T feel it change into high gear. Brian Dunnigan
Re: Trans Question
[Re: Garceau]
#953763
03/19/11 11:42 PM
03/19/11 11:42 PM
Kindafast
Seaford, Va
Thanks guy's . I took Cabs advice and hit it pretty hard. It hit 2nd real hard when I was turning it up. So far it seems to work pretty good.
6.50 @105.26
Re: Trans Question
[Re: Kindafast]
#953764
03/20/11 02:23 PM
03/20/11 02:23 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
Hey Kindafast.... If you have any other questions on 727's call Kurt at Magnum Machine (in your sig).... he has a lot of hardcore flite stuff for 7 and 8 second trans and is a wealth of knowledge.
Randy
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
