Trans Question
#953758
03/19/11 03:14 PM
03/19/11 03:14 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey guys, I have a question if you could answer it. I just went to a 727 race transmission with a ton of aftermarket parts in it I drove it around the block and shifts fine. The problem I have is It seems a little soft shifting into 2nd gear. No slip at all and I have adjusted the front band. The transmission shifts real hard into 3rd gear but it just feels a little soft into 2nd. This is a old Turbo Action Manual valve body. I have not really shifted it under full power yet. It does have a pretty high 8" stall in it about 5500. Any ideas ?
6.50 @105.26
Re: Trans Question
[Re: Cab_Burge]
#953760
03/19/11 03:52 PM
03/19/11 03:52 PM
Kindafast
Seaford, Va
Thanks Cab , The shifter is adjusted right , it's right on the money with the detent on the shifter. The trans shifts pretty hard into 3rd gear no matter what rpm I am at. I am hoping it's not hanging up on 2nd gear like you said. I will take it back out and hit it and see what it does from there. I will let you know . Thanks,
6.50 @105.26
Re: Trans Question
[Re: Garceau]
#953763
03/19/11 11:42 PM
03/19/11 11:42 PM
Kindafast
Seaford, Va
Thanks guy's . I took Cabs advice and hit it pretty hard. It hit 2nd real hard when I was turning it up. So far it seems to work pretty good.
6.50 @105.26
Re: Trans Question
[Re: Kindafast]
#953764
03/20/11 02:23 PM
03/20/11 02:23 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
Hey Kindafast.... If you have any other questions on 727's call Kurt at Magnum Machine (in your sig).... he has a lot of hardcore flite stuff for 7 and 8 second trans and is a wealth of knowledge.
Randy
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
