Stock stroke 360 on the dyno
#949257
03/12/11 03:49 PM
03/12/11 03:49 PM
Posts: 1,051 The Great White North
RAMM
Ok so it isn't exactly a race engine but it is fairly strong for what it is. What is it? Here's the rundown: '78 360 .040" linehoned/decked, stock stroke cast crankshaft cut .010"/.020" Eagle SIR rods, KB 107's, pocket ported 'J heads 1.94"/1.60" , Professional Products Crosswind intake, Lunati VooDoo hydraulic cam #60404, stock stamped rockers, Holley 750 dbl, garden variety 1 5/8" street style headers, Magnaflow mufflers, etc...
Considering the 9.7 comp ratio, open chamber J heads that were mildly worked and subsequently registered 231 cfm @.480" on the SF-1020, I really wasn't expecting much more than 400 hp and maybe 415 lb/ft at the peaks. I will definately be using this camshaft, in this combination again. The customer reports excellent manners on the street with a good strong surge of power to well above 6000+ rpm. So here it is on the dyno with some data to accompany the above. I feel this engine is very representative of a mild 360 build that should be fun on the street and not breaking the bank. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: Stock stroke 360 on the dyno
[Re: RAMM]
#949258
03/12/11 03:50 PM
03/12/11 03:50 PM
RAMM
Sheet of the first pull. J.Rob
[Re: RAMM]
#949259
03/12/11 03:53 PM
03/12/11 03:53 PM
RAMM
Here's one of the last pull for today. Not bad huh? J.Rob
[Re: RAMM]
#949260
03/12/11 03:54 PM
03/12/11 03:54 PM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
Nice motor, Bullet-proof 440+ hp smallblock, iron heads and hydraulic cam, kickin' it old school and that's WAY KEWL!!
[Re: RAMM]
#949261
03/12/11 03:54 PM
03/12/11 03:54 PM
RAMM
We were obviously having a little fun. Still very interesting though, I thought. Blew the customer's mind. J.Rob
[Re: MuuMuu101]
#949263
03/12/11 03:57 PM
03/12/11 03:57 PM
RAMM
Forgot to mention that this was tested on 89 octane mid grade winter fuel. Up here it's known as MacEwen's gas. Some further testing on Monday but not much. J.Rob
[Re: RAMM]
#949265
03/12/11 04:04 PM
03/12/11 04:04 PM
Posts: 2,578 sweden
1Fast340
sweden
looks to be a very good build for some streetfun with lots of torque down low and good power upstairs something that just hit me on how flat the power goes at 5500-6000 could it be one of these two reasons 1.running out of air basicly from ports not flowing anymore? 2.some kind of instability in the valvetrain? not a profesional just checking if what litle i may have picked up over the years could be the right thoughts
[Re: 1Fast340]
#949268
03/12/11 06:18 PM
03/12/11 06:18 PM
Posts: 2,128 sweden
sshemi
sweden
I would say both heads and cam. I had one like that but with M1 intake and .557 mopar cam it went 11.5 in a -66 valiant
[Re: goldmember]
#949270
03/12/11 09:44 PM
03/12/11 09:44 PM
RAMM
The only changes were the addition of a 1.5" Wilson 4 hole spacer and I packed the intake with snow. Timing was not changed for any pull and remained @ 35 total. J.Rob
[Re: RAMM]
#949271
03/12/11 11:03 PM
03/12/11 11:03 PM
Posts: 164 mesa arizona
moturbopar
mesa arizona
Wow making me rethink my cam choice. My build is similar, but i have 2.02 valves M1 single plane, but a comp ex268. That lunati cam really runs well and make power all over the place.
[Re: Dunnuck Racing]
#949274
03/12/11 11:35 PM
03/12/11 11:35 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I suppose there is a similar spec cam for BB? I have a mild 383 (stock 906 heads, stock bottom end) that I might consider using one in.
383, Hemi 4-Speed, AlterKtion, D60
