Page 1 of 3 1 2 3
Stock stroke 360 on the dyno #949257
03/12/11 03:49 PM
03/12/11 03:49 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Ok so it isn't exactly a race engine but it is fairly strong for what it is. What is it? Here's the rundown: '78 360 .040"
linehoned/decked, stock stroke cast crankshaft cut .010"/.020"
Eagle SIR rods, KB 107's, pocket ported 'J heads 1.94"/1.60" , Professional Products Crosswind intake, Lunati VooDoo hydraulic cam #60404, stock stamped rockers, Holley 750 dbl, garden variety 1 5/8" street style headers, Magnaflow mufflers, etc...
Considering the 9.7 comp ratio, open chamber J heads that were mildly worked and subsequently registered 231 cfm @.480" on the SF-1020, I really wasn't expecting much more than 400 hp and maybe 415 lb/ft at the peaks. I will definately be using this camshaft, in this combination again. The customer reports excellent manners on the street with a good strong surge of power to well above 6000+ rpm. So here it is on the dyno with some data to accompany the above. I feel this engine is very representative of a mild 360 build that should be fun on the street and not breaking the bank. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Stock stroke 360 on the dyno [Re: RAMM] #949258
03/12/11 03:50 PM
03/12/11 03:50 PM
RAMM Offline OP
RAMM  Offline OP
Sheet of the first pull. J.Rob
Re: Stock stroke 360 on the dyno [Re: RAMM] #949259
03/12/11 03:53 PM
03/12/11 03:53 PM
RAMM Offline OP
RAMM  Offline OP
Here's one of the last pull for today. Not bad huh? J.Rob
Re: Stock stroke 360 on the dyno [Re: RAMM] #949260
03/12/11 03:54 PM
03/12/11 03:54 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Nice motor,
Bullet-proof 440+ hp smallblock, iron heads and hydraulic cam, kickin' it old school and that's WAY KEWL!!
WIZE
In Car:
Re: Stock stroke 360 on the dyno [Re: RAMM] #949261
03/12/11 03:54 PM
03/12/11 03:54 PM
RAMM Offline OP
RAMM  Offline OP
We were obviously having a little fun. Still very interesting though, I thought. Blew the customer's mind. J.Rob
Re: Stock stroke 360 on the dyno [Re: RAMM] #949262
03/12/11 03:55 PM
03/12/11 03:55 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Nice engine! Looks like it could would do good in a strong street car.
Re: Stock stroke 360 on the dyno [Re: MuuMuu101] #949263
03/12/11 03:57 PM
03/12/11 03:57 PM
RAMM Offline OP
RAMM  Offline OP
Forgot to mention that this was tested on 89 octane mid grade winter fuel. Up here it's known as MacEwen's gas. Some further testing on Monday but not much. J.Rob
Re: Stock stroke 360 on the dyno [Re: RAMM] #949264
03/12/11 04:03 PM
03/12/11 04:03 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
I built one just the same, same KB 107 pistons, same heads, but I went one notch lower with the cam with th 286/276 one
and I used stock valve sizes on the heads....and a preformer intake, eddy carb.
I was impressed on how hard it pulled for what it was....
I was leaving my buddy with his 65 350 vette and my other buddy with his 65 Mustang Fback which had a 302 with aluminum eddy heads, and a bunch of other stuff in the dust!!!
Re: Stock stroke 360 on the dyno [Re: RAMM] #949265
03/12/11 04:04 PM
03/12/11 04:04 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
looks to be a very good build for some streetfun with lots of torque down low and good power upstairs
something that just hit me on how flat the power goes at 5500-6000 could it be one of these two reasons
1.running out of air basicly from ports not flowing anymore?
2.some kind of instability in the valvetrain?
not a profesional just checking if what litle i may have picked up over the years could be the right thoughts
Re: Stock stroke 360 on the dyno [Re: domingo] #949266
03/12/11 04:06 PM
03/12/11 04:06 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Re: Stock stroke 360 on the dyno [Re: domingo] #949267
03/12/11 04:07 PM
03/12/11 04:07 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Re: Stock stroke 360 on the dyno [Re: 1Fast340] #949268
03/12/11 06:18 PM
03/12/11 06:18 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I would say both heads and cam.
I had one like that but with M1 intake and .557 mopar cam it went 11.5 in a -66 valiant
Re: Stock stroke 360 on the dyno [Re: RAMM] #949269
03/12/11 08:02 PM
03/12/11 08:02 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd like to know what changes were made between the 1st and last dyno runs.
Re: Stock stroke 360 on the dyno [Re: goldmember] #949270
03/12/11 09:44 PM
03/12/11 09:44 PM
RAMM Offline OP
RAMM  Offline OP
The only changes were the addition of a 1.5" Wilson 4 hole spacer and I packed the intake with snow. Timing was not changed for any pull and remained @ 35 total. J.Rob
Re: Stock stroke 360 on the dyno [Re: RAMM] #949271
03/12/11 11:03 PM
03/12/11 11:03 PM
mesa arizona
moturbopar Offline
moturbopar  Offline
mesa arizona
Wow making me rethink my cam choice. My build is similar, but i have 2.02 valves M1 single plane, but a comp ex268. That lunati cam really runs well and make power all over the place.
Re: Stock stroke 360 on the dyno [Re: RAMM] #949272
03/12/11 11:18 PM
03/12/11 11:18 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Nice little small block,glad to see you posting this stuff.Maybe I will do the same soon.
Keith
Re: Stock stroke 360 on the dyno [Re: moturbopar] #949273
03/12/11 11:35 PM
03/12/11 11:35 PM
SoCal
Brian Hafliger Offline
SoCal
I just did a similar 360 with the 268 cam and 9.7:1 and it made 380HP.
More cam and carb really make a difference but some guys want a "good" idle.
I wish I had some snow laying around!! LOL..that was classic. Did you learn that from the EMC?
Are you going this year? I still haven't ran our pig with different heads...been swamped the last 7 months.
Brian Hafliger
Re: Stock stroke 360 on the dyno [Re: Dunnuck Racing] #949274
03/12/11 11:35 PM
03/12/11 11:35 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
I suppose there is a similar spec cam for BB? I have a mild 383 (stock 906 heads, stock bottom end) that I might consider using one in.
383, Hemi 4-Speed, AlterKtion, D60
Re: Stock stroke 360 on the dyno [Re: Brian Hafliger] #949275
03/13/11 09:46 AM
03/13/11 09:46 AM
RAMM Offline OP
RAMM  Offline OP
Yeah this is pretty much one of the only times I like having snow on the ground. No I didn't learn that from the EMC as I am always testing in September. I learned that in Grade 8 science-about volumes and densities and their relationships to temperature. Yes I did apply for the EMC again-I would really like to give it one more shot. Probably a big block again--I really like the B engine-hint hint.. You never did get back to me with more details on how your testing went J.Rob
Re: Stock stroke 360 on the dyno [Re: RAMM] #949276
03/13/11 10:18 AM
03/13/11 10:18 AM
Central NC
gch Offline
gch  Offline
Central NC
Dyno sheet says 830 holley and text says 750.Which one?Is it just me or is the a/f ratio on the first run pig rich down low and still rich up top?
Nice numbers.Gives me ideas for the rebuilt 360 I just bought for peanuts with a 727.
Page 1 of 3 1 2 3
