Re: Six Pack Gurus?
[Re: B5 Bee]
#945865
03/12/11 02:17 PM
03/12/11 02:17 PM
Posts: 43,347 Bend,OR USA
Cab_Burge
I have a dual plane intake on my car (eddy) now and want to try a single plane. I'm running indy srs mildly ported, best time last year was [Email]6.87@98[/Email] 1/8th car weighs 3550 w me in it. Where do I get one for a six pack or whats the best way to build one?
There are three options that I'm aware of, Indy two piece with the six pak lid, custom made sheet metal intake and the last is the old Weiand Super Stock cast aluminum two piece semi tunnel ram six pak intakes.IHTHs
You're forgetting one Cab, the Eldebrock STR-14 with the six pack top.
Oops, your correct, my memory is horrible:o I have seen pictures of them but never owned or work on one of them Another option would be a tunnel ram with a homemade top like Sixpak Gut used lots of options when you wnat to make your own ![](/ubbthreads/images/graemlins/scope.gif)
Re: Six Pack Gurus?
[Re: Cab_Burge]
#945866
03/12/11 02:26 PM
03/12/11 02:26 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Your memory isn't horrible, Cab - we all skip a beat now and then. ![](/ubbthreads/images/graemlins/beer.gif)
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: Six Pack Gurus?
[Re: Evil Spirit]
#945873
03/14/11 04:46 PM
03/14/11 04:46 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I run a STR-14-6 with mechanical carbs. The motor is a .060 over 440 w/ Eddy heads, 10.7 cr, and a Comp hydraulic in a 66 Coronet. I bought the STR partly because I was told "It will never work". I didn't believe that. I'm knocking on the 10 second door w/ a best of 11.03 @ 119. I'm working on a weight loss program......
I always wonder when I see a car with a 6 barrel that has a slightly low MPH to the ET if it's running out of air/carburetion. A setup up like yours would be easy to swap to a 2X4 barrel top with a pair of 600's for a good comparison. I'm not saying anything is wrong with your combo - it runs real hard - just curious about if it could use a little more air.
its not the carbs, its the intakes. and IMO, i personally dont see me gaining much if anything on my combo if i bolted on a dominator
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Six Pack Gurus?
[Re: sixpackgut]
#945876
03/14/11 11:08 PM
03/14/11 11:08 PM
Posts: 228 northeast texas
strokin73cuda
northeast texas
I don,t think I have any problem with my carbs either, I ran at thunder road this sat first full quarter passes on my car with 4.56s and 28.5 effective ht on my wore out 325 -50 15 mickey thompson radials in 4 passes I could never get it to hook but ran 99+mph on every pass at the 660' and 121+mph every pass at the 1220' my et suffered from the spinning with a best 1.67 60' 10.93 et ,my 60' is usually low 1.50s The problem lies with my intake being a (dual plane) stock style-stock port window-mill with runners as crooked as polititions are famous for being. I have no "six boggers" on my ride very much Thanks to Mr. Cab and Mr. Ray (sixpackgut) helping me learn to tune it, although I can,t see a big difference in my holley 2 bbls and holley 4 bbls wich use the same parts. I would be willing anyday to let anyone switch it to a 4-bbl settup with a similar intake as mine and see if it will pick-up any et and I would be willing to bet they will be dissapointed with the results. I would simply like to try the best for the buck single plane intake under my very reliable six pack. ![](/ubbthreads/images/graemlins/biggrin.gif)
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
