Page 2 of 6 1 2 3 4 5 6
Re: NGK Plugs ? [Re: Brian Hafliger] #944339
03/06/11 10:21 PM
03/06/11 10:21 PM
NC
440Jim Offline
440Jim  Offline
NC
BCP7ES for the street.
If the 7 doesn't last (cold), drop down to the BCP6ES...
With that "low" CR, you don't want too cold of a plug like the -9 NGK. IMO, a -7 will be about the coldest I would run.
Re: NGK Plugs ? [Re: joedust451] #944340
03/06/11 10:22 PM
03/06/11 10:22 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
autolite ar3922 or if a little bit colder ar3911
autolite plugs make about 5-10 hp more than ngk plugs all the time,, thought the ngk are easier to read
I will try them in the BB TR deal we'll dyno in a week or so.
Please do Brian, curious to know, post results
me three
Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: NGK Plugs ? [Re: Brian Hafliger] #944341
03/06/11 10:25 PM
03/06/11 10:25 PM
mopar65 Offline
mopar65  Offline
As a fellow BB TR user could you tell us some info about the build? if you have to you can pm me. thanks Mopar65
Re: NGK Plugs ? [Re: dennismopar73] #944342
03/06/11 11:22 PM
03/06/11 11:22 PM
detroit area
moderncylinder Offline
detroit area
are you saying there is no truth to my statement? thats just my experience,, ive done it a few times on my dyno and its always worth power
in a ss hemi gained 10
in a ss 427 chevy gained 10
in a pump gas small chevy gained 6
in a 480 cubic inch fe pump gas was worth 8
in a 505 bb mopar pump gas was worth 6
all average power numbers which is all i ever look at
so i built a small blk ford motor for a guy local who works for the prince of quatar(alanabi guy),, so he is hooked up with shannon jenkins from some nitrous company,, i told my customer to run autolite plugs but they didnt cause they later told me i didnt tell them a part number,,, so they ran ngk,, so they went down south and shannon told them to go to the store and get some autolite plugs cause they make more power than ngk plugs,,, so they did cause they were told to by two totaly different sources. its a 360 cubic inch 8.2 deck ford with tfs heads in a 2900lb car, clutchless 5 spd,, nitrous,, been 7.80's at 180something
Re: NGK Plugs ? [Re: moderncylinder] #944343
03/07/11 04:01 AM
03/07/11 04:01 AM
SoCal
Brian Hafliger Offline
SoCal
And that is why we test folks!
Brian Hafliger
Re: NGK Plugs ? [Re: Brian Hafliger] #944344
03/07/11 09:24 AM
03/07/11 09:24 AM
ky
68roadrunner Offline
ky
and we appreciate the testing and information that everybody brings here.
Re: NGK Plugs ? [Re: moderncylinder] #944345
03/07/11 12:10 PM
03/07/11 12:10 PM
ill
dennismopar73 Offline
ill
i will believe that there might be a minisque diff in some plugs
as in heat range tips lenghts , ets but to come make bold statements
that this plug will make more hp than the same equivalent plug from diffrent plug manufacture , is totally without merit ,
now if youre testing a totaly diffrent plug vs a racing style plug
with diffrent heat range , then i will believe some of youre statement!
other than that, show me dyno results with no other changes than
that of a plug change, using the same indexing , timing, etc
just a plug change thats all ,, lets see the results!!
Re: NGK Plugs ? [Re: dennismopar73] #944346
03/07/11 12:23 PM
03/07/11 12:23 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I have a hard time believing this to but hopefully he's right that will be the cheapest horspower I have made in a while
Re: NGK Plugs ? [Re: BLONDE BARRACUDA] #944347
03/07/11 12:27 PM
03/07/11 12:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Horse power TV always makes that type of power increase with the plug of the month
Re: NGK Plugs ? [Re: Brian Hafliger] #944348
03/07/11 12:57 PM
03/07/11 12:57 PM
gregsdart Online content
gregsdart  Online Content
440-1 NGK-9-what is the equivalent Auto lite? Willing to try them.
Re: NGK Plugs ? [Re: mopar65] #944349
03/07/11 01:47 PM
03/07/11 01:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
12.5 Stealth headed 440 I run NGK R5671A-8.My kids price at Advanced was about 14 bucks for 8.Great plug.Car runs better than when I ran the Autolites.Rocky
Chrysler Firepower
Re: NGK Plugs ? [Re: therocks] #944350
03/07/11 04:27 PM
03/07/11 04:27 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have ran both the AR 3911 and the NGK 7173 both extended tip only change was plug in my case car ran same et but with the AR 3911 I gained 1 mph and the car idles much better this was back to back test same day 30 minutes apart.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: NGK Plugs ? [Re: dusturbd340W5] #944351
03/07/11 04:48 PM
03/07/11 04:48 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
This was replacing and old set with new AR's & new NGK's? or were you replacing the NGK's with AR's?
Re: NGK Plugs ? [Re: dusturbd340W5] #944352
03/07/11 05:07 PM
03/07/11 05:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Woody... whats the compression on your engine... was
that with the W-5s
Re: NGK Plugs ? [Re: MR_P_BODY] #944353
03/07/11 05:18 PM
03/07/11 05:18 PM
UK
602heavy Offline
602heavy  Offline
UK
Don't wanna rain on anyones parade here but..........................................if ANY of you believe a HP gain when swapping out a new NGK for the equivilant Autolite you better go back to basics..............they call it HOGWASH.
Re: NGK Plugs ? [Re: 602heavy] #944354
03/07/11 06:25 PM
03/07/11 06:25 PM
detroit area
detroit area
it works for me,,, i have my own dyno,, it repeats.... party on guys
Re: NGK Plugs ? [Re: moderncylinder] #944355
03/07/11 06:58 PM
03/07/11 06:58 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Thanks for the info Jeff.
Re: NGK Plugs ? [Re: MR_P_BODY] #944356
03/07/11 07:21 PM
03/07/11 07:21 PM
Kissimmee Fl.
Kissimmee Fl.
that with the W-5s
no this was with the Indybrocks with the motor at 12.5-1 and that was install brand new NGK's made 1 pass then installed brand new AR 3911.
The test was done because my machinist swears by the Ar's
Re: NGK Plugs ? [Re: dusturbd340W5] #944357
03/07/11 07:39 PM
03/07/11 07:39 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i have bbeen running the NGK R5671A-9's for yrs..
if Jeff says they are worth an improvement..thats good enough for me..
i agree the chrome/nickle base is easier to read then the black phosfate.
i think they have a nickle version fwiw...i just dont know the part number..
what # Autolite plug is a direct cross match from the NGK R5671A-9 plug?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: NGK Plugs ? [Re: dusturbd340W5] #944358
03/07/11 07:47 PM
03/07/11 07:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
that with the W-5s
I'm trying to figure out what plug to run in my W-5s
for my drag week car, 11:1 ... I've been using Champion
race plugs for my W-9 but they are pretty pricey
