Re: NGK Plugs ?
[Re: joedust451]
#944320
03/06/11 07:09 PM
03/06/11 07:09 PM
Posts: 43,296 Bend,OR USA
Cab_Burge
-7 or-8 on the last( ) number depending on the fuel and the tune up I like the extended tips plugs also I can go look at the numbers on the plugs if you need them
Re: NGK Plugs ?
[Re: joedust451]
#944321
03/06/11 07:09 PM
03/06/11 07:09 PM
What part # or heat range NGK would work best in a .030" 440 with Indy EZ heads, FT pistons, compressions at 11.1, Resistor or non-Resistor.
5672A-9
Re: NGK Plugs ?
[Re: moderncylinder]
#944323
03/06/11 07:17 PM
03/06/11 07:17 PM
Posts: 1,137 Home of the Bluegrass
MoparJunkie
Will those work with Eddy heads also? (not trying to jack your thread, just asking...)
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: NGK Plugs ?
#944325
03/06/11 07:30 PM
03/06/11 07:30 PM
Posts: 554 Kentucky
clovis
Kentucky
R5671A-8 (4224) is non-projected tip (right) $3.99/ea R5672A-8 (7173) is a projected tip (left) $1.99/ ea joe, is this a project for the dart ?
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: NGK Plugs ?
[Re: clovis]
#944326
03/06/11 07:35 PM
03/06/11 07:35 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
What Dart
No, just helping out a friend
I'm sure the Projected tip would work better for NA.
Hey Chris, Have you fixed the Duster yet??
Re: NGK Plugs ?
[Re: 602heavy]
#944329
03/06/11 08:16 PM
03/06/11 08:16 PM
Posts: 554 Kentucky
clovis
Kentucky
joe, its coming together. I am hoping to get the block, crank and rods from the machine shop this week. The converter is here, heads are almost done and the dana is going in this weekend. if all goes well should have it to the track by mid April.
Re: NGK Plugs ?
[Re: 602heavy]
#944330
03/06/11 08:28 PM
03/06/11 08:28 PM
Stay away from the projected style plug , NGK-6 will be fine on the street & track , will be difficult to read if any colder.
The lower the number the hotter the plug 10 being the coldest 6 being the hottest.
Re: NGK Plugs ?
[Re: clovis]
#944332
03/06/11 08:54 PM
03/06/11 08:54 PM
joedust451
super gas
super gas
Branson, Mo.
Cool, so are you getting rid of the 906s?
Re: NGK Plugs ?
#944333
03/06/11 09:34 PM
03/06/11 09:34 PM
Posts: 1,200 UK
602heavy
UK
-5 being the hottest , to cold a plug will load up , used -6 with no problem on an 11.5:1 street motor , 7s are ok but a tad cold when 'cruising' around , the projected type plug will get too hot due to the ground strap being deep into the combustion chamber , ok for a stock type motor running low compression , the projected type plug will glow like an ember when running high compression street motors.
Re: NGK Plugs ?
#944334
03/06/11 09:38 PM
03/06/11 09:38 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
autolite ar3922 or if a little bit colder ar3911
autolite plugs make about 5-10 hp more than ngk plugs all the time,, thought the ngk are easier to read
Now theres good tech right there! I think I'll give that a try in the spring. Thanks Jeff.
Re: NGK Plugs ?
#944335
03/06/11 09:43 PM
03/06/11 09:43 PM
Posts: 1,200 UK
602heavy
UK
wow...
Re: NGK Plugs ?
[Re: Brian Hafliger]
#944337
03/06/11 10:05 PM
03/06/11 10:05 PM
joedust451
super gas
super gas
Branson, Mo.
I will try them in the BB TR deal we'll dyno in a week or so.
Please do Brian, curious to know, post results
