Solid Flat Tappet Differences #936216
02/24/11 09:00 AM
02/24/11 09:00 AM
Indiana
Cuda_Mike Offline OP
Indiana
I received my new cam and lifters yesterday, RB engine, the lifter on the right is what came with it. I've never used any like these, what's the point of the reduced o.d.? 87 grams, 122 grams and 100 grams respectively.
Re: Solid Flat Tappet Differences [Re: Cuda_Mike] #936217
02/24/11 09:12 AM
02/24/11 09:12 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Hey Mike what brand are those,they look like slant six lifters to me.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Solid Flat Tappet Differences [Re: moparmxz] #936218
02/24/11 09:23 AM
02/24/11 09:23 AM
Indiana
Indiana
Randy, I don't remember the name of manufacturer, they came in a Bullet Racing Cams box. The light one on the left is Mopar Perf., the middle one Comp. I was surprised of the difference in weight, and that the full bodied Mopar unit was lighter that the one from Bullet.
Re: Solid Flat Tappet Differences [Re: Cuda_Mike] #936219
02/24/11 09:46 AM
02/24/11 09:46 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The MP solid lifter is the lightest two piece (hollow) I have measured.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Solid Flat Tappet Differences [Re: Rapid340] #936220
02/24/11 10:54 AM
02/24/11 10:54 AM
NC
440Jim Online work
440Jim  Online Work
NC
Yes, the MP lifter is hollow inside. If you remove the clip, then the pushrod seat, you will see the space underneath.
Mike,
Can you make some measurements of the barbell shaped lifter? If you don't have a dial caliper, just to the 1/16" inch would still be informative.
Re: Solid Flat Tappet Differences [Re: 440Jim] #936221
02/24/11 11:18 AM
02/24/11 11:18 AM
Indiana
Indiana
Jim, I have a dial caliper and will measure it when I get home, about 5 p.m. Are there any drawbacks to this design?
Re: Solid Flat Tappet Differences [Re: Cuda_Mike] #936222
02/24/11 11:28 AM
02/24/11 11:28 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Are you aware that if you use the barbell design w/o bushed lifter bores, you will have NO oil pressure due to excessive oil getting past the cutout in the lifter body?
Re: Solid Flat Tappet Differences [Re: BradH] #936223
02/24/11 11:36 AM
02/24/11 11:36 AM
Indiana
Indiana
Brad, That is what I was wondering, that's why I asked. Thanks. I guess these need to go back. Thanks.
Re: Solid Flat Tappet Differences [Re: Cuda_Mike] #936224
02/24/11 09:22 PM
02/24/11 09:22 PM
Indiana
Indiana
Jim, Here are the dimensions of the lifter. What's it designed for? Thanks for all replies.
Re: Solid Flat Tappet Differences [Re: BradH] #936225
02/24/11 09:41 PM
02/24/11 09:41 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Brad is correct...
Re: Solid Flat Tappet Differences [Re: Quicksilver440] #936226
02/24/11 10:36 PM
02/24/11 10:36 PM
okla.
sam64 Offline
sam64  Offline
okla.
if the top[.590]part doesn't come out of the lifter bore it shouldn't lose pressure,right.
Re: Solid Flat Tappet Differences [Re: sam64] #936227
02/24/11 11:11 PM
02/24/11 11:11 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If the top part does come out of the hole theres going to be some serious stabilty issues.
The barbell part is at the oil feed, but it will just fill and oil the bore more evenly. I dont see how it will lose all oil psi. Its going to fill and only leak out around the perimeter of the lifters bore. Its not going to Dump into a unpressurized opening.
Personally I dont like that new design. I like the full body better, but I guess the barbell could work just as well. But , your going to have to add the extra grams of excess oil of the filled part of the barbell handle to the overall lifters weight thats going to be pushed around.
The benefits if any is the full 360* lifter bore oiling vs just the regular side bore feed oiling. There may be some more slight oil leakage with loose bores but thats dousing the cam mostly. Maybe a poormans EDM lifter.
Re: Solid Flat Tappet Differences [Re: Cuda_Mike] #936228
02/24/11 11:22 PM
02/24/11 11:22 PM
That looks like a solid lifter designed for a BB Chevy motor using .904( .903 modification on Chevy lifter bores ) lifter sizes
Re: Solid Flat Tappet Differences [Re: Cab_Burge] #936229
02/25/11 11:09 AM
02/25/11 11:09 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
We run mopars also they are lighter and been told 5 thousand under size. Comps are heavy .
But I had a mishap last year with one ,nobody has seen this happen .
We believe the lashcap broke and caused too much lash ,or the hole in lifter made too much lash broke lashcap .
witch came 1st chicken or egg.
Pic of it
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Solid Flat Tappet Differences [Re: Cuda_Mike] #936230
02/25/11 01:14 PM
02/25/11 01:14 PM
NC
440Jim Online work
440Jim  Online Work
NC
Thanks Mike. I will put that info in my file.
Re: Solid Flat Tappet Differences [Re: 10 o to go] #936231
02/25/11 01:31 PM
02/25/11 01:31 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I had about 8 mopar performace lifters do that over 3 ton 4 years! I used to carry spares and spare pushrods for road side fixes. then I heard some friends had the same failours with mopar performance lifters. bought Comp Cams lifters and never had another problem???
Re: Solid Flat Tappet Differences [Re: Cuda_Mike] #936232
02/25/11 01:54 PM
02/25/11 01:54 PM
NC
440Jim Online work
440Jim  Online Work
NC
Mike, for comparison
this is info I have for the Howards EDM face oiling lifters. They are overall slightly taller than the MP lifters, with an oil band that didn't give me any issues with 0.650" lift. Two sources had some variation in the numbers, but FWIW.
Re: Solid Flat Tappet Differences [Re: 440Jim] #936233
02/25/11 01:59 PM
02/25/11 01:59 PM
NC
440Jim Online work
440Jim  Online Work
NC
And this is some other notes I have saved.
Re: Solid Flat Tappet Differences [Re: 440Jim] #936234
02/25/11 02:40 PM
02/25/11 02:40 PM
NC
440Jim Online work
440Jim  Online Work
NC
Here is the best I can ESTIMATE, from this info. You better check if the barbell lifter cut out gets exposed at the bottom of the lifter bore when the cam is on the base circle (zero lift). It looks close. I don't have a dimension for that. The purple lines are approximately what I saw with my Howards lifters and a 0.650" lift cam (0.433 tappet lift).
Re: Solid Flat Tappet Differences [Re: 440Jim] #936235
02/25/11 03:10 PM
02/25/11 03:10 PM
Central Valley, CA.
Central Valley, CA.
Jim...it always amazes me how much info you compile.
