Page 3 of 4 1 2 3 4
Re: "C" clip eliminators. [Re: DoctorDiff] #934257
02/24/11 12:40 PM
02/24/11 12:40 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Luckily, 8 3/4" housing ends fit OEM 9 1/4" brakes.
Didn't Rick Ehrenburg used Ford end in his 64. It had an 83/4 and he Ford end and kept the existing brakes. He does not like the green bearing. He use a sealed tapered Ford bearing. Matt
Re: "C" clip eliminators. [Re: MattW] #934258
02/24/11 02:27 PM
02/24/11 02:27 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Doesn't answer your question, but here is a pic of how the axle tube transitions from 4" to 3" about mid way on the tube. I would guess you could use any end that is made for a 3" tube with a press in bearing? I would perfer to use my existing brakes ( 11"x 2 1/2") as they stop my heavy weight well and are well matched to the fronts.
Fastest 300
Re: "C" clip eliminators. [Re: MattW] #934259
02/24/11 02:32 PM
02/24/11 02:32 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can use your existing brakes as-is if you use standard 8 3/4" billet ends.
You can also use hybrid 3.15" bore Mopar housing ends and a Timken set 20 or a Ford sealed ball wheel bearing if you want to bore the center out of your original backing plates.
If a few people are interested, I could probably make a bolt-on C-clip eliminator/axle package for a 9 1/4" rearend.
Re: "C" clip eliminators. [Re: DoctorDiff] #934260
02/24/11 02:36 PM
02/24/11 02:36 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Like Adobe said above - there's a whole bunch of Dakota guys running the 9.25 that are skirting the rules that would be VERY interested in a bolt-on option. So far, none of us have broken axles or really torn up much more than the LSD unit.
Re: "C" clip eliminators. [Re: Duner] #934261
02/24/11 03:01 PM
02/24/11 03:01 PM
MD
ADakotaRTGuy Offline
MD
I took the hard road, Moser big ford ends, fit perfectly, Moser 31 spline axles, Moser Torino Budget brakes.
Come on Dave, You know I did this on my truck already.
Re: "C" clip eliminators. [Re: DoctorDiff] #934262
02/24/11 05:00 PM
02/24/11 05:00 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I'm interested!
Fastest 300
Re: "C" clip eliminators. [Re: ADakotaRTGuy] #934263
02/24/11 08:26 PM
02/24/11 08:26 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Two words...Hard & Road...LOL
There's more than enough interest for c-clip eliminator axle packages.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: "C" clip eliminators. [Re: Adobedude] #934264
02/24/11 09:36 PM
02/24/11 09:36 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What is the cost of changing ends, etc on the 9.25?
How close would you be to getting a Dana 60 and being done with the issue and have a better selling point if you decide to get out?
Re: "C" clip eliminators. [Re: DoctorDiff] #934265
02/24/11 10:12 PM
02/24/11 10:12 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Would the timken # BR20 fit the original axles?
I am thinking cheap.
Weld ends on and press bearings on original axles and go.
Re: "C" clip eliminators. [Re: SomeCarGuy] #934266
02/24/11 11:43 PM
02/24/11 11:43 PM
MD
MD
If all you are doing is changing the ends and putting in new axles its not bad. 100 for the ends, 200 to cut off and weld new ends, then the cost of the axles. Assuming your brakes cross over.
Re: "C" clip eliminators. [Re: MattW] #934267
02/25/11 12:08 AM
02/25/11 12:08 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, no unitized bearing would be a simple, press on deal.
I looked at a few options today, and I think a 9.25" C-clip eliminator/axle package is do-able. I will start to chip away at the design.
Re: "C" clip eliminators. [Re: DoctorDiff] #934268
02/25/11 01:05 AM
02/25/11 01:05 AM
Greenville, SC
bad360rt Offline
bad360rt  Offline
Greenville, SC
Re: "C" clip eliminators. [Re: bad360rt] #934269
02/25/11 11:43 AM
02/25/11 11:43 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks!!
Fastest 300
Re: "C" clip eliminators. [Re: DoctorDiff] #934270
02/25/11 03:21 PM
02/25/11 03:21 PM
HR3128 Offline
HR3128  Offline
Let me know when you get the package worked out. I will take one.
Re: "C" clip eliminators. [Re: HR3128] #934271
02/25/11 04:35 PM
02/25/11 04:35 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
X2
Seriously there are over a million of these rear ends out there, once the word gets out maybe spool, pro gears.
i
Re: "C" clip eliminators. [Re: MattW] #934272
02/25/11 04:41 PM
02/25/11 04:41 PM
MD
MD
A spool for bigger axles would be great.
Re: "C" clip eliminators. [Re: ADakotaRTGuy] #934273
02/25/11 06:38 PM
02/25/11 06:38 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Do you think street/strip '97-'04 6 lug Dakota axles with 3" studs would be the most popular application?
I assume everyone understands installing C-clip eliminators requires cutting the wheel bearing pockets off the housing, so nothing protrudes past the brake backing plates?
Re: "C" clip eliminators. [Re: DoctorDiff] #934274
02/25/11 07:26 PM
02/25/11 07:26 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
5 lug, one of the more common Dakota complaints is lack of wheels for a 6 lug.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: "C" clip eliminators. [Re: Adobedude] #934275
02/26/11 12:55 AM
02/26/11 12:55 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I could supply axles with dual 6 and 5 lug patterns.
Re: "C" clip eliminators. [Re: DoctorDiff] #934276
02/26/11 03:34 PM
02/26/11 03:34 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Sounds good...5 lug would seal the deal for a lot of guys. I have 6 lug Bogarts...But they were stupid expensive, and strip only. When we do find 6 lug race wheels, that's all they are, race only...Never street/strip.
I could post up an info thread in a couple Dakota forums when you get more info
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Page 3 of 4 1 2 3 4
