a question for the moparts resto gurus on bolts
#932500
02/19/11 07:18 PM
02/19/11 07:18 PM
Posts: 5,797 minnarusta
TX9H6E4CUDA
minnarusta
So I have all these bead blasted,freshly painted bolts for putting together my superbee. How do you keep from guffing up the paint on them? So what are your secrets to acheaving this? This is my first total resto of a car and I want it to look great and something I can be totally proud of......any tips
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: a question for the moparts resto gurus on bolts
[Re: TX9H6E4CUDA]
#932501
02/19/11 07:21 PM
02/19/11 07:21 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
Not a Guru but - Easy - Put them on before you paint.......... Oh, too late? You should strip them again, install and hit them with a jamb gun maybe.
[Re: FJ5_Fish]
#932502
02/19/11 07:35 PM
02/19/11 07:35 PM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
I have heard of putting electrical tape or similar inside the sockets. Not sure how good it works but might be worth a try.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: ChickMaggot]
#932505
02/19/11 09:52 PM
02/19/11 09:52 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
These might work.
Maggot
Not only would they work they'd keep you from scratching your nuts too.
[Re: 5wndwcpe]
#932506
02/19/11 10:14 PM
02/19/11 10:14 PM
FJ5_Fish
Ontario, Canada
These might work.
Maggot
No more embarrassment for my wife!
[Re: Shoozy]
#932508
02/20/11 03:43 AM
02/20/11 03:43 AM
Posts: 5,669 South Dakota
hotairballoonpilot
South Dakota
I bought a set from snap on a few years ago that were regular sixe sockets with plastic inserts. Worked ok until I needed to tighted the bolts down. The inserts just started rounding out. I would guess that those others listed would do the same. I just touch them up after words. Hate to but like others say paint assembled to avoid.
Contact Me about AMD Prices
[Re: hotairballoonpilot]
#932509
02/20/11 03:47 AM
02/20/11 03:47 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Oh, too late?
[Re: ScottSmith_Harms]
#932510
02/20/11 03:57 AM
02/20/11 03:57 AM
TX9H6E4CUDA
minnarusta
The reason I cannot paint the bolts while it is assembled is I have almost every piece under the car, other then bolts powder coated and I really do not want to get overspray on my freshly done parts. I will try the electrical tape but of it comes down to it I will just touch them up with a little brush.
[Re: TX9H6E4CUDA]
#932513
02/20/11 07:48 PM
02/20/11 07:48 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Use an Airbrush for your fine painting details/touchups. You can literally paint a "pencil" line and never see where the old paint starts and the new paint stops. The Airbrush can spray a pattern so nice that the bolt heads will look as if the paint is bleeding from their surface. It is probably one of (if not) the most important detailing tools to finish those hard to reach "touch ups" and not get ANY over-spray on your surrounding parts. You can set the spray so fine that you can't see the paint leaving the nozzle tip. Once you use an Airbrush, you will wonder how you ever got along without one!
[Re: anlauto]
#932515
02/20/11 08:11 PM
02/20/11 08:11 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Is that what they did on the assembly line, before delivering the cars new ?
Only if there's a Y91 on the BS
[Re: DAYCLONA]
#932516
02/20/11 09:45 PM
02/20/11 09:45 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
[Re: anlauto]
#932517
02/20/11 10:35 PM
02/20/11 10:35 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Are you serious Alan? Please tell me you are not going to start nit picking the restoration processes that I use in contrast with yours or anybody else out there. Nowhere have I ever claimed that we restore vehicles using "exact" factory procedures. Restorers are basically illusionist who try to emulate the characteristics of a factory built vehicle! Did you really think that my cars were restored on an assembly line like they originally were built by the Factory? Wow!!!! Thanks for the tremendous compliment Alan.
[Re: DodgeMaterial]
#932519
02/20/11 11:22 PM
02/20/11 11:22 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Dave - You blew it (as in muffler water!) Now you will have to admit all the things we did that were not like the assembly plant... like using hand tools instead of pneumatic tools, taking our time (18 months) instead of 18 hours...etc. Way to go!
You ought to go back and look at some of the hilarious comments that people have made in an attempt to debunk what we did! The angle that Steve spray painted the starter was wrong! We used an airbrush to help make painted parts look new again instead of leaving them damaged looking. Don't forget the one about the alternator being restored "incorrectly" even though that is how we documented it!
Dave, are we the only restoration guys that had to touch up mishaps that occurred during the assembly process? Either some of these guys have access to factory equipment that we were not privileged to use during our restorations, or they don't realize that every insult simply exposes their own hypocrisy! Maybe Alan will let us use his overhead conveyor with the 250 foot dip tank for dipping the body or let us have access to his assembly line pit for installing the engine or the paint booth and baking oven just like Hamtramck used or the robotics used to help install the Dash...........
