a question for the moparts resto gurus on bolts #932500
02/19/11 07:18 PM
02/19/11 07:18 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
So I have all these bead blasted,freshly painted bolts for putting together my superbee. How do you keep from guffing up the paint on them? So what are your secrets to acheaving this? This is my first total resto of a car and I want it to look great and something I can be totally proud of......any tips
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: a question for the moparts resto gurus on bolts [Re: TX9H6E4CUDA] #932501
02/19/11 07:21 PM
02/19/11 07:21 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Not a Guru but - Easy - Put them on before you paint..........
Oh, too late?
You should strip them again, install and hit them with a jamb gun maybe.
Re: a question for the moparts resto gurus on bolts [Re: FJ5_Fish] #932502
02/19/11 07:35 PM
02/19/11 07:35 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have heard of putting electrical tape or similar inside the sockets. Not sure how good it works but might be worth a try.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: a question for the moparts resto gurus on bolts [Re: TX9H6E4CUDA] #932503
02/19/11 07:41 PM
02/19/11 07:41 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Some of the bolts (fenders & hinges, for example) are attached before painting, so they're painted at the same time as the panels if you're painting the car similar to the factory method. For the bolts that you paint and then install later, depending on size/fastener torque, masking tape around the hex, or plastic inserts in the tool socket, work pretty well. Invariably some get touched up. I always make sure I have more than enough fasteners as spares, in case one gets garfed more than I want to touch up.
Re: a question for the moparts resto gurus on bolts [Re: TX9H6E4CUDA] #932504
02/19/11 09:15 PM
02/19/11 09:15 PM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
These might work.
Maggot
You can lead a gift horse to water, but you
can't look in his mouth.
Re: a question for the moparts resto gurus on bolts [Re: ChickMaggot] #932505
02/19/11 09:52 PM
02/19/11 09:52 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
These might work.
Maggot
Not only would they work they'd keep you from scratching your nuts too.
Re: a question for the moparts resto gurus on bolts [Re: 5wndwcpe] #932506
02/19/11 10:14 PM
02/19/11 10:14 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
These might work.
Maggot
No more embarrassment for my wife!
Re: a question for the moparts resto gurus on bolts [Re: 5wndwcpe] #932507
02/19/11 10:16 PM
02/19/11 10:16 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
These might work.
Maggot
We're guys. That's what we do...
Old, tired, and sometimes broke down. Me, not my car...
Re: a question for the moparts resto gurus on bolts [Re: Shoozy] #932508
02/20/11 03:43 AM
02/20/11 03:43 AM
South Dakota
hotairballoonpilot Offline
South Dakota
I bought a set from snap on a few years ago that were regular sixe sockets with plastic inserts. Worked ok until I needed to tighted the bolts down. The inserts just started rounding out. I would guess that those others listed would do the same. I just touch them up after words. Hate to but like others say paint assembled to avoid.
Contact Me about AMD Prices
Re: a question for the moparts resto gurus on bolts [Re: hotairballoonpilot] #932509
02/20/11 03:47 AM
02/20/11 03:47 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Oh, too late?
Re: a question for the moparts resto gurus on bolts [Re: ScottSmith_Harms] #932510
02/20/11 03:57 AM
02/20/11 03:57 AM
minnarusta
minnarusta
The reason I cannot paint the bolts while it is assembled is I have almost every piece under the car, other then bolts powder coated and I really do not want to get overspray on my freshly done parts. I will try the electrical tape but of it comes down to it I will just touch them up with a little brush.
Re: a question for the moparts resto gurus on bolts [Re: TX9H6E4CUDA] #932511
02/20/11 01:10 PM
02/20/11 01:10 PM
SE Pa.
LimeliteAero Offline
SE Pa.
On two cars that I partially restored I just wrapped the heads with pieces of paper towel, didnt know about the plastic inserts at the time. I know how backyard the paper towel deal is but my paint stayed in perfect condition throughout the assembly process.
Re: a question for the moparts resto gurus on bolts [Re: TX9H6E4CUDA] #932512
02/20/11 07:35 PM
02/20/11 07:35 PM
Minn
SportF Offline
SportF  Offline
Minn
I have played this game a couple of times and I believe the best way to do it is to prime your bolts lightly and either put one light coat of paint on them or none at all. After install, touch them up with a small brush with un-thinned paint. If you fully paint them that paint will chip or curl up and then you have that problem. Fully painted bolts are also larger and don't want to fit in any socket. Touching them up with a brush won't really show due to the finish and contour of the bolt heads.
Re: a question for the moparts resto gurus on bolts [Re: TX9H6E4CUDA] #932513
02/20/11 07:48 PM
02/20/11 07:48 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Use an Airbrush for your fine painting details/touchups. You can literally paint a "pencil" line and never see where the old paint starts and the new paint stops. The Airbrush can spray a pattern so nice that the bolt heads will look as if the paint is bleeding from their surface. It is probably one of (if not) the most important detailing tools to finish those hard to reach "touch ups" and not get ANY over-spray on your surrounding parts. You can set the spray so fine that you can't see the paint leaving the nozzle tip. Once you use an Airbrush, you will wonder how you ever got along without one!
Re: a question for the moparts resto gurus on bolts [Re: ECS] #932514
02/20/11 08:04 PM
02/20/11 08:04 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Is that what they did on the assembly line, before delivering the cars new ?
CHECK OUT MY NEW WEB SITE !
Re: a question for the moparts resto gurus on bolts [Re: anlauto] #932515
02/20/11 08:11 PM
02/20/11 08:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Only if there's a Y91 on the BS
Re: a question for the moparts resto gurus on bolts [Re: DAYCLONA] #932516
02/20/11 09:45 PM
02/20/11 09:45 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Re: a question for the moparts resto gurus on bolts [Re: anlauto] #932517
02/20/11 10:35 PM
02/20/11 10:35 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Are you serious Alan? Please tell me you are not going to start nit picking the restoration processes that I use in contrast with yours or anybody else out there. Nowhere have I ever claimed that we restore vehicles using "exact" factory procedures. Restorers are basically illusionist who try to emulate the characteristics of a factory built vehicle! Did you really think that my cars were restored on an assembly line like they originally were built by the Factory? Wow!!!! Thanks for the tremendous compliment Alan.
Re: a question for the moparts resto gurus on bolts [Re: ECS] #932518
02/20/11 10:54 PM
02/20/11 10:54 PM
St. Louis, MO
DodgeMaterial Offline
St. Louis, MO
Dave - You blew it (as in muffler water!) Now you will have to admit all the things we did that were not like the assembly plant... like using hand tools instead of pneumatic tools, taking our time (18 months) instead of 18 hours...etc. Way to go!
DodgeMaterial - Dave JS29U0B - FK5 - 440-4 Auto WS23V0A - EB5 - 440-6 Auto
Re: a question for the moparts resto gurus on bolts [Re: DodgeMaterial] #932519
02/20/11 11:22 PM
02/20/11 11:22 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
You ought to go back and look at some of the hilarious comments that people have made in an attempt to debunk what we did! The angle that Steve spray painted the starter was wrong! We used an airbrush to help make painted parts look new again instead of leaving them damaged looking. Don't forget the one about the alternator being restored "incorrectly" even though that is how we documented it!
Dave, are we the only restoration guys that had to touch up mishaps that occurred during the assembly process? Either some of these guys have access to factory equipment that we were not privileged to use during our restorations, or they don't realize that every insult simply exposes their own hypocrisy! Maybe Alan will let us use his overhead conveyor with the 250 foot dip tank for dipping the body or let us have access to his assembly line pit for installing the engine or the paint booth and baking oven just like Hamtramck used or the robotics used to help install the Dash...........
