Re: Small block heads bolts
[Re: JSR1485]
#925350
02/10/11 01:05 PM
02/10/11 01:05 PM
Posts: 2,826 NY usa
540challenger
NY usa
I knew the small block head bolts never got any sealant on the threads but I did not know that using studs or the wrong diameter bolts or studs would cause a oil restiction to the heads? Anybody run into problems with this?
Your just a little confused the headbolt have nothing to do with it.
The bolts/stud used on the rocker shafts is what supplies the oil. The stock bolt have a reduced shank for the oiling holes in the stands. And yes using the wrong one could limit the supplie to the shafts
[Re: 540challenger]
#925352
02/10/11 01:39 PM
02/10/11 01:39 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
Per Jim Szilagyi quote: The oil path to the heads is really complicated compared to most engines. Sometimes if the wrong head bolts are used,oil can be restricted to the cylinder heads. The head bolts have a reduced area to allow more oil flow around the bolt and up to the heads. The oil flows from #2 and #4 camshaft journals through oil passage in the deck to the heads. I am aware of the of 3/8 bolts and larger holes at the bottom of the rocker shafts.
Switched to the dark side...
[Re: JSR1485]
#925353
02/10/11 02:33 PM
02/10/11 02:33 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Rocker shaft bolts are 5/16. The a non threaded portion of the bolt hole being larger than the threaded portion for oil passage to the rocker shaft/top end oiling.
[Re: MoparforLife]
#925354
02/10/11 03:04 PM
02/10/11 03:04 PM
JSR1485
Seaford Delaware
I should have said that using 3/8 bolts over 5/16 will cause a problem and I am aware of that.
[Re: JSR1485]
#925355
02/10/11 09:17 PM
02/10/11 09:17 PM
RapidRobert
It's on page 38 of his stroker handbook, just a misprint, should say rocker arm holddown bolts instead of head bolts EDIT meant to say rocker shaft holdown bolts ![](/ubbthreads/images/graemlins/wink.gif)
