Small block heads bolts #925349
02/10/11 01:01 PM
02/10/11 01:01 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I knew the small block head bolts never got any sealant on the threads but I did not know that using studs or the wrong diameter bolts or studs would cause a oil restiction to the heads? Anybody run into problems with this?
Switched to the dark side...
Re: Small block heads bolts [Re: JSR1485] #925350
02/10/11 01:05 PM
02/10/11 01:05 PM
NY usa
540challenger Offline
NY usa
Your just a little confused the headbolt have nothing to do with it.
The bolts/stud used on the rocker shafts is what supplies the oil. The stock bolt have a reduced shank for the oiling holes in the stands. And yes using the wrong one could limit the supplie to the shafts
Re: Small block heads bolts [Re: 540challenger] #925351
02/10/11 01:33 PM
02/10/11 01:33 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
One small block head bolt is longer than the rest. It has a reduced shank diameter to allow oil up to the rocker shaft stand.
Re: Small block heads bolts [Re: 540challenger] #925352
02/10/11 01:39 PM
02/10/11 01:39 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
Per Jim Szilagyi quote: The oil path to the heads is really complicated compared to most engines. Sometimes if the wrong head bolts are used,oil can be restricted to the cylinder heads. The head bolts have a reduced area to allow more oil flow around the bolt and up to the heads.
The oil flows from #2 and #4 camshaft journals through oil passage in the deck to the heads.
I am aware of the of 3/8 bolts and larger holes at the bottom of the rocker shafts.
Re: Small block heads bolts [Re: JSR1485] #925353
02/10/11 02:33 PM
02/10/11 02:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Rocker shaft bolts are 5/16. The a non threaded portion of the bolt hole being larger than the threaded portion for oil passage to the rocker shaft/top end oiling.
Re: Small block heads bolts [Re: MoparforLife] #925354
02/10/11 03:04 PM
02/10/11 03:04 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I should have said that using 3/8 bolts over 5/16 will cause a problem and I am aware of that.
Re: Small block heads bolts [Re: JSR1485] #925355
02/10/11 09:17 PM
02/10/11 09:17 PM
It's on page 38 of his stroker handbook, just a misprint, should say rocker arm holddown bolts instead of head bolts EDIT meant to say rocker shaft holdown bolts
