904/998/999 ID'ing? #924096
02/08/11 10:15 PM
02/08/11 10:15 PM
Milwaukee, WI
Prince_Valiant Offline OP
Milwaukee, WI
Working w/ a 79 volare...
How can I tell which one I have? It's not a lock-up trans, that much I know...
does it matter?
Trans needs to be rebuilt, need to know so I make sure I get the correct parts.
tia,
chris
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: 904/998/999 ID'ing? [Re: Prince_Valiant] #924097
02/08/11 11:47 PM
02/08/11 11:47 PM
I'm wondering how to tell the diff also. might post the # stamped on the pan rail so someone can ID it
Re: 904/998/999 ID'ing? [Re: RapidRobert] #924098
02/09/11 08:54 AM
02/09/11 08:54 AM
scratchnfotraction Online tonguue
scratchnfotraction  Online Tonguue
yep,#s on the pan rail will tell the story on it
then when its opend up,you will know if its been worked already also
Re: 904/998/999 ID'ing? [Re: scratchnfotraction] #924099
02/09/11 08:42 PM
02/09/11 08:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
904 = /6
998 = 318
999 = 360
At least in that era. All flavors for the same trans though.
Don't be the exception.
Re: 904/998/999 ID'ing? [Re: scratchnfotraction] #924100
02/09/11 08:52 PM
02/09/11 08:52 PM
Milwaukee, WI
Milwaukee, WI
Where exactly are the numbers usually located? There's a lot of grime on this trans, so I'm sure they'll pop up once we clean it a bit, but it's not too obvious where they are now...
thanks for the info...I'll post up the numbers when we find them
Re: 904/998/999 ID'ing? [Re: Prince_Valiant] #924101
02/10/11 03:26 AM
02/10/11 03:26 AM
5thAve Offline
5thAve  Offline
Go by what the number says. It's stamped on a flat surface right over the pan.
Re: 904/998/999 ID'ing? [Re: 5thAve] #924102
02/10/11 04:41 PM
02/10/11 04:41 PM
Milwaukee, WI
Milwaukee, WI
Okay...the numbers that were found were as grouped:
4180972 6394 5478
can anyone decipher these?
Re: 904/998/999 ID'ing? [Re: Prince_Valiant] #924103
02/10/11 05:34 PM
02/10/11 05:34 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Looking here:
http://www.mymopar.com/downloads/transguide.pdf
I'd say your number is 4130972, which is late 79 904 from a 318.
Found that link in another trans ID thread here:
https://board.moparts.org/ubbthreads/show...rue#Post6466924
As far as ID to get the right parts -
It depends on how much you'll be replacing. Look at the listing for various parts kits, the application dates will tell you how far they cover, and the exact year/model might not matter (like on a seal/gasket kit). But if you're putting clutches in, you'd need to know if it was a 5-disc police unit or not.
Re: 904/998/999 ID'ing? [Re: Prince_Valiant] #924104
02/10/11 05:40 PM
02/10/11 05:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
6394 is the build date February 1, 1979.
