Re: New 4" Crank Dome Piston Offering from Wiseco Pistons
[Re: Dartwizer]
#923998
02/14/11 08:49 PM
02/14/11 08:49 PM
Posts: 526 NC
barracuda man
NC
When are they going into production?
x2 RyanJ on the 416cu at 14:1 compression.What head gaskit is used. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: barracuda man]
#923999
02/14/11 08:55 PM
02/14/11 08:55 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Cometic is all I use above 11:1
They are waiting for new batch of Forgings, but if you "need" a set ASAP, they are willing to do run of Customs in this spec for same cost until they get caught back up on forgings. The new forgings are supposed to be few weeks out & will have a .250" exhaust pocket for increased piston to valve with the bigger cams.
[Re: RyanJ]
#924000
02/14/11 09:13 PM
02/14/11 09:13 PM
Posts: 526 NC
barracuda man
NC
Will they be a package deal with pins and rings. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RyanJ]
#924001
02/14/11 09:26 PM
02/14/11 09:26 PM
Posts: 526 NC
barracuda man
NC
I'm looking for 11:5 to 12:1 compression on the 418cu.I have 65"cometic gaskits.what compression will i have with a 65cc eldlebrock 340 heads. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Discoquik]
#924005
03/15/11 11:04 PM
03/15/11 11:04 PM
Posts: 526 NC
barracuda man
NC
Due date for all oversizes is 3/18/11 for finished parts in all oversizes. We did some internal milling to take some weight out with added dome rise that is needed to compensate for the deeper valve pocket. Wound up a little lighter than the samples sent to Ryan, Indy, Muscle Motors, Bob G, Koffel, Hughes, and Compuflow.
Should be able to order through any distributor with K0011B3/4/6/8 or 100 oversize part numbers and includes piston, rings, and clips.
.927" pin versions do not have a part number as of yet, but in process.
As a side note 318 flat top and dish parts are on the way for 4.00" stroker combos in the Pro Tru line.
Any update on the pistons. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: barracuda man]
#924006
03/15/11 11:24 PM
03/15/11 11:24 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
[Re: meus31]
#924009
05/02/11 04:53 PM
05/02/11 04:53 PM
CompWedgeEngines
Syracuse,NY
Brett,
I have a sample you can look at. I will try to call you later tonight.
Todd
RIP Monte Smith
