Re: big block roller lifters whats my options
[Re: shoebox]
#922329
02/06/11 04:41 PM
02/06/11 04:41 PM
Dyno1
[Re: Diablo]
#922333
02/06/11 07:01 PM
02/06/11 07:01 PM
Posts: 16,929 NC
440Jim
NC
comp cams will be just fine
Which Comp roller lifters? They have several choices with different features and price, so not all have all features. Direct oiled axles, offset pushrod seat, pushrod oiling, tall lifter body, etc.
For the original poster, what valve spring pressures (seat and open), lobe/valve lift, and rpm will you be running?
[Re: Brian Hafliger]
#922335
02/06/11 07:11 PM
02/06/11 07:11 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
I was thinking of the 892's. Then he has the option of the .210 offset. I would also recommend the lifters right above this post If they had the .210 offset i would had ordered those a year ago.
[Re: bigtimeauto]
#922338
02/06/11 08:26 PM
02/06/11 08:26 PM
i use crowers
Them's the ones I just started using also.
#922339
02/06/11 08:58 PM
02/06/11 08:58 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Comp still hasn't started using our lifters so they're still available
Ok, who is "our" ???
#922341
02/06/11 11:06 PM
02/06/11 11:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
IMM engines. I helped design these lifters with the manufacturer. Comp grinds cams...that's really it. Yes they do R&D, but most of the products they sell are made for them private label. And EVERY other cam company does the same thing.
Comp now uses our sb design lifters, but so far they have not given a part # to the BB lifters so I'm free to sell them. Brian
I have a set of Brian's SB roller lifters with the push rod oiling.... very nice lifter
[Re: shoebox]
#922344
02/07/11 01:42 AM
02/07/11 01:42 AM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
I like Lunati roller lifters, reasonable price and a quality piece.
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: poppaj]
#922345
02/07/11 04:13 AM
02/07/11 04:13 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Morel makes Lunati lifters, Bullet lifters and many others. Morel has recently released a lower priced lifter, so don't automatically think you are getting an $800 lifter for cheap. Lifters is an area where you definitely get what you pay for.
Monte
#922346
02/07/11 07:25 AM
02/07/11 07:25 AM
Posts: 6,295 U.S.
moparniac
U.S.
How much do the crowers run Bobby? Or don't you sell them?
Mopar Performance
