big block roller lifters whats my options #922328
02/06/11 04:38 PM
02/06/11 04:38 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
i know T&D and jesel are the best and thats whats going to be recommened here but lets start by saying... it aint gonna happen. the high end stuff is way out of the budget. im talking more in the lines of howards,herbert,comp etc.. which ones/who's brand oils through the pushrods? im ethier going to do iron rockers from RAS or comp magnums in which i need BALL BALL pushrods.
so which roller lifters do you recommend for a budget 440
herbert,howards,lunati,etc...
74 dart sport 440 www.Csucarbs.com
Re: big block roller lifters whats my options [Re: shoebox] #922329
02/06/11 04:41 PM
02/06/11 04:41 PM
Dyno1 Offline
Dyno1  Offline
Comp Cams
Re: big block roller lifters whats my options [Re: shoebox] #922330
02/06/11 06:11 PM
02/06/11 06:11 PM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
Herberts. RAS on the rockers, shafts, hold downs. Manton oil fed adjusters.
Re: big block roller lifters whats my options [Re: Moparteacher] #922331
02/06/11 06:16 PM
02/06/11 06:16 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I'm happy with my Herberts.....
Randy
Re: big block roller lifters whats my options [Re: Dartin] #922332
02/06/11 06:50 PM
02/06/11 06:50 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
comp cams will be just fine
Re: big block roller lifters whats my options [Re: Diablo] #922333
02/06/11 07:01 PM
02/06/11 07:01 PM
NC
440Jim Offline
440Jim  Offline
NC
Which Comp roller lifters? They have several choices with different features and price, so not all have all features. Direct oiled axles, offset pushrod seat, pushrod oiling, tall lifter body, etc.
For the original poster, what valve spring pressures (seat and open), lobe/valve lift, and rpm will you be running?
Re: big block roller lifters whats my options [Re: 440Jim] #922334
02/06/11 07:07 PM
02/06/11 07:07 PM
SoCal
Brian Hafliger Offline
SoCal
Comp still hasn't started using our lifters so they're still available.
Low skirt, pushrod oiling, bearings oiled, and straight or .180 offset. Oil hole is moved as well to be out of the galley so it doesn't pump oil.
Re: big block roller lifters whats my options [Re: Brian Hafliger] #922335
02/06/11 07:11 PM
02/06/11 07:11 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I was thinking of the 892's. Then he has the option of the .210 offset.
I would also recommend the lifters right above this post
If they had the .210 offset i would had ordered those a year ago.
Re: big block roller lifters whats my options [Re: Diablo] #922336
02/06/11 07:17 PM
02/06/11 07:17 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
brian can i get a pm price check on somthing like that! looks good. i forgot about yours. folks the cams going to be somthing like 255 600 108 nothing too radical. i have some iron rockers that i want tot send to RAS for the works OR there are some comp magnums with the roller tip... but need pushrod oiling
Re: big block roller lifters whats my options [Re: shoebox] #922337
02/06/11 07:23 PM
02/06/11 07:23 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
i use crowers
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: big block roller lifters whats my options [Re: bigtimeauto] #922338
02/06/11 08:26 PM
02/06/11 08:26 PM
i use crowers
Them's the ones I just started using also.
Re: big block roller lifters whats my options [Re: Brian Hafliger] #922339
02/06/11 08:58 PM
02/06/11 08:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ok, who is "our" ???
Re: big block roller lifters whats my options [Re: Stanton] #922340
02/06/11 10:47 PM
02/06/11 10:47 PM
SoCal
SoCal
IMM engines. I helped design these lifters with the manufacturer. Comp grinds cams...that's really it. Yes they do R&D, but most of the products they sell are made for them private label.
And EVERY other cam company does the same thing.
Comp now uses our sb design lifters, but so far they have not given a part # to the BB lifters so I'm free to sell them.
Brian
Brian Hafliger
Re: big block roller lifters whats my options [Re: Brian Hafliger] #922341
02/06/11 11:06 PM
02/06/11 11:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Brian
I have a set of Brian's SB roller lifters with the
push rod oiling.... very nice lifter
Re: big block roller lifters whats my options [Re: MR_P_BODY] #922342
02/06/11 11:50 PM
02/06/11 11:50 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Brian what did you design on that lifter? I have talked the the same guy you get them from and they are his design. Its a comp AMC lifter. All the lifter you sell are made by the company Comp has contracted to manufacture them. If you use the lifter in your picture without bushing the block it with have oil pressure problems. If the block is bushed correctly you do not need the oil hole parallel with the axle. Just use the correct Comp Brand lifter and you will be fine. Brian its great to help people but to take credit for someone elses work, come on.
Re: big block roller lifters whats my options [Re: PETE@BESTMACHINE] #922343
02/07/11 01:12 AM
02/07/11 01:12 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Re: big block roller lifters whats my options [Re: shoebox] #922344
02/07/11 01:42 AM
02/07/11 01:42 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
I like Lunati roller lifters, reasonable price and a quality piece.
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: big block roller lifters whats my options [Re: poppaj] #922345
02/07/11 04:13 AM
02/07/11 04:13 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Morel makes Lunati lifters, Bullet lifters and many others. Morel has recently released a lower priced lifter, so don't automatically think you are getting an $800 lifter for cheap. Lifters is an area where you definitely get what you pay for.
Monte
Re: big block roller lifters whats my options [Re: Brian Hafliger] #922346
02/07/11 07:25 AM
02/07/11 07:25 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
How much do the crowers run Bobby? Or don't you sell them?
Mopar Performance
Re: big block roller lifters whats my options [Re: moparniac] #922347
02/07/11 02:08 PM
02/07/11 02:08 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
im thinking herberts are the ones im going with. i called them and they said they do oil through the pushrods. any herbert roller lifter users confirm that? sales guy sounded iffy lol
