Re: tow vehicle help?
[Re: Quicktree]
#921455
02/05/11 03:24 PM
02/05/11 03:24 PM
Posts: 1,532 off the grid
340B5
off the grid
I was refering to the round canister under the hood. It will suck up moisture like nobody's business in a matter of minutes, rendering it useless.
Yeah, it's got a smallblock.
[Re: Quicktree]
#921457
02/05/11 03:33 PM
02/05/11 03:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
that dash top new is around 260-280 $ you can get a cover ,, if you dash isnt completely gone @ 125-150$
I found a new oem dash on ebay for $196. the old truck still runs good but everything is falling apart around it. the whole thing needs replacing but I have to make it work somehow. just can't afford a new one.
I need to keep mine running also... sort of a specialized vehicle for my trailer/trailers
[Re: MR_P_BODY]
#921458
02/05/11 04:33 PM
02/05/11 04:33 PM
340B5
off the grid
I just like mine. Didn't really like the front end/grille when they first came out. It's grown on me. So has the 40K I'd be missing if I bought another.
[Re: MR_P_BODY]
#921459
02/05/11 05:52 PM
02/05/11 05:52 PM
Quicktree
dang Raff somebody attached a large lunch box on yours. say to Woody and Ellen.
[Re: 340B5]
#921460
02/05/11 05:53 PM
02/05/11 05:53 PM
Quicktree
yea it's out the question for us also.
[Re: Quicktree]
#921461
02/05/11 06:02 PM
02/05/11 06:02 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Cheapest I've seen aftermarket dash pads for Rams is 280-300. Don' bother with another factory one unless you don't mind it cracking again. Some real junk, thin plastic from the vendor; Textron, I believe. Seen this on most 94 - up Rams in the bone yard, along with Neons. Someone ought to get together a class action suit against Chrysler to replace them all. MANY MANY Rams have this problem, over many years. The pad is also connected by molded in studs to all of the air duct tubes and such. Real pita to just replace the pad without pulling the whole dash and undoing all those duct connections. Mine thankfully all snapped off. I glued that sucker back together with about 8 tubes of Devcon plastic cement and put a cover over it. The dash surround bezel even more fragile and brittle than the pad.
[Re: Sixpak]
#921462
02/05/11 06:25 PM
02/05/11 06:25 PM
Posts: 12,120 City of Champions
Prostock
City of Champions
My dash is busted to hell and back. My truck came from Texas, and has never seen a garage up here.
I have a molded cloth cover over mine. I can't remember what it cost but it wasn't all that expensive.
[Re: rowin4]
#921465
02/06/11 12:50 AM
02/06/11 12:50 AM
Posts: 354 Livonia Michigan
440dart
Livonia Michigan
Does anybody know if durangos use the same process I need to replace the evaporator
Yes I live in Michigan, so there is still 1 light on
[Re: rowin4]
#921466
02/06/11 08:22 AM
02/06/11 08:22 AM
Quicktree
anybody ever had to change a heater core in their ram 3500? mine is a 97 and the dash is shot. started cracking and falling apart when I tried to remove it. is there a link or something to help?
...feets linked this about 3 days ago.
http://www.dieseltruckresource.com/dev/remove-hvac-box-t248580.html?t=248580
All I can say is WOW!!!!!! If mine starts to leak it will see a gallon of bar's leak before I do that. Good post, I'll file that away for a nightmare.
after looking at that I say WoW also in those pics it looks like you dont even have to remove the top dash cap what a freakin nightmare. can't believe they couldn't design a better way and I agree the dash cracking issue is pathetic at best.
[Re: slantzilla]
#921469
02/06/11 11:57 AM
02/06/11 11:57 AM
Quicktree
If it's like my '00 Dakota, it sounds like the process is very similar. Replace the heater core for sure too, it will be leaking.
you would think with todays technology we could make a core that would never leak. my home a/c coil (trane) started leaking after 3 years. they said it was a common problem. they replaced it with a bronze coated coil and said after that treatment they haven't had any problems.
[Re: kens avenger]
#921471
02/06/11 12:06 PM
02/06/11 12:06 PM
Quicktree
you can swivel the dash and getbthe heater core out it will take @ 5-6 hours,, while you are there replace the ac core as well well know for leaks there so if you ac keeps losing its cool ,that is where it mostlikley is ,, so go ahad and chang that,, being youre in florida!!
takes less then 1 hr to do this job.. the dash cover will take alittle longer.. tony if you need to call me.. its not hard after you do one its easy....PM me for my # if you want
only problem I have is I don't have any way to do the a/c side.
