Re: tow vehicle help? [Re: Quicktree] #921454
02/05/11 03:11 PM
02/05/11 03:11 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
anybody ever had to change a heater core in their ram 3500? mine is a 97 and the dash is shot. started cracking and falling apart when I tried to remove it. is there a link or something to help?
...feets linked this about 3 days ago.
http://www.dieseltruckresource.com/dev/remove-hvac-box-t248580.html?t=248580
Re: tow vehicle help? [Re: Quicktree] #921455
02/05/11 03:24 PM
02/05/11 03:24 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I was refering to the round canister under the hood. It will suck up moisture like nobody's business in a matter of minutes, rendering it useless.
Yeah, it's got a smallblock.
Re: tow vehicle help? [Re: thehemikid] #921456
02/05/11 03:25 PM
02/05/11 03:25 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
My heater core started leaking in my ford 5 years ago, One bottle of Barrs leak did the deed
Re: tow vehicle help? [Re: Quicktree] #921457
02/05/11 03:33 PM
02/05/11 03:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
that dash top new is around 260-280 $
you can get a cover ,, if you dash isnt completely
gone
@ 125-150$
I found a new oem dash on ebay for $196. the old truck still runs good but everything is falling apart around it. the whole thing needs replacing but I have to make it work somehow. just can't afford a new one.
I need to keep mine running also... sort of a specialized
vehicle for my trailer/trailers
Re: tow vehicle help? [Re: MR_P_BODY] #921458
02/05/11 04:33 PM
02/05/11 04:33 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I just like mine. Didn't really like the front end/grille when they first came out. It's grown on me. So has the 40K I'd be missing if I bought another.
Re: tow vehicle help? [Re: MR_P_BODY] #921459
02/05/11 05:52 PM
02/05/11 05:52 PM
Q
Quicktree Offline OP
Q
gone
@ 125-150$
dang Raff somebody attached a large lunch box on yours. say to Woody and Ellen.
Re: tow vehicle help? [Re: 340B5] #921460
02/05/11 05:53 PM
02/05/11 05:53 PM
Q
Q
yea it's out the question for us also.
Re: tow vehicle help? [Re: Quicktree] #921461
02/05/11 06:02 PM
02/05/11 06:02 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
gone
@ 125-150$
Cheapest I've seen aftermarket dash pads for Rams is 280-300. Don' bother with another factory one unless you don't mind it cracking again. Some real junk, thin plastic from the vendor; Textron, I believe. Seen this on most 94 - up Rams in the bone yard, along with Neons. Someone ought to get together a class action suit against Chrysler to replace them all. MANY MANY Rams have this problem, over many years.
The pad is also connected by molded in studs to all of the air duct tubes and such. Real pita to just replace the pad without pulling the whole dash and undoing all those duct connections. Mine thankfully all snapped off. I glued that sucker back together with about 8 tubes of Devcon plastic cement and put a cover over it. The dash surround bezel even more fragile and brittle than the pad.
Re: tow vehicle help? [Re: Sixpak] #921462
02/05/11 06:25 PM
02/05/11 06:25 PM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
gone
@ 125-150$
My dash is busted to hell and back. My truck came from Texas, and has never seen a garage up here.
I have a molded cloth cover over mine. I can't remember what it cost but it wasn't all that expensive.
Re: tow vehicle help? [Re: Quicktree] #921463
02/05/11 11:54 PM
02/05/11 11:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hey Tony ... I need to carry alot of lunch... I
eat A LOT ... your buddy Woody took the
wife and myself out and showed us a good time...
almost meet one of his personal friends... LOL
(he'll tell you)... to bad you couldnt have made
it over for a visit, we had a good time... and yes
your name came up a few times
Hope you got the dash and heater core out
Re: tow vehicle help? [Re: thehemikid] #921464
02/06/11 12:30 AM
02/06/11 12:30 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
All I can say is WOW!!!!!! If mine starts to leak it will see a gallon of bar's leak before I do that. Good post, I'll file that away for a nightmare.
Re: tow vehicle help? [Re: rowin4] #921465
02/06/11 12:50 AM
02/06/11 12:50 AM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
Does anybody know if durangos use the same process I need to replace the evaporator
Yes I live in Michigan, so there is still 1 light on
Re: tow vehicle help? [Re: rowin4] #921466
02/06/11 08:22 AM
02/06/11 08:22 AM
Q
Q
after looking at that I say WoW also in those pics it looks like you dont even have to remove the top dash cap what a freakin nightmare. can't believe they couldn't design a better way and I agree the dash cracking issue is pathetic at best.
Re: tow vehicle help? [Re: 440dart] #921467
02/06/11 09:50 AM
02/06/11 09:50 AM
ill
dennismopar73 Offline
ill
YES IT DOES
Re: tow vehicle help? [Re: 440dart] #921468
02/06/11 11:36 AM
02/06/11 11:36 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If it's like my '00 Dakota, it sounds like the process is very similar. Replace the heater core for sure too, it will be leaking.
Re: tow vehicle help? [Re: slantzilla] #921469
02/06/11 11:57 AM
02/06/11 11:57 AM
Q
Q
you would think with todays technology we could make a core that would never leak. my home a/c coil (trane) started leaking after 3 years. they said it was a common problem. they replaced it with a bronze coated coil and said after that treatment they haven't had any problems.
Re: tow vehicle help? [Re: dennismopar73] #921470
02/06/11 12:02 PM
02/06/11 12:02 PM
Tampa Fl
K
kens avenger Offline
mopar addict
mopar addict
K
Tampa Fl
you can swivel the dash and getbthe heater core out
it will take @ 5-6 hours,,
while you are there replace the ac core as well
well know for leaks there
so if you ac keeps losing its cool ,that is where it
mostlikley is ,,
so go ahad and chang that,, being youre in florida!!
takes less then 1 hr to do this job.. the dash cover will take alittle longer.. tony if you need to call me.. its not hard after you do one its easy....PM me for my # if you want
Remember in here some don't think you should have a Opinion.. sad fact..
Re: tow vehicle help? [Re: kens avenger] #921471
02/06/11 12:06 PM
02/06/11 12:06 PM
Q
Q
mostlikley is ,,
only problem I have is I don't have any way to do the a/c side.
Re: tow vehicle help? [Re: Quicktree] #921472
02/06/11 12:41 PM
02/06/11 12:41 PM
408Dust Offline
408Dust  Offline
Lucky for you it's a truck. Replace a evap. in a Neon,LHS or an older Daytona.
