Re: What can I use to seal my tranny cover FOREVER?
[Re: SkynyrdTim]
#915976
01/28/11 05:20 PM
01/28/11 05:20 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Are you sure it is leak from the pan ? maybee comming from plug inside the bell for kick down lever shaft . Or maybee the case has a crack or the vent is plugged . i work on subaru cars and the factory puts the pans on with this pink factory trans silione type sealer and let me tell you if you use that you could take the bolts out and drive forever after it sets up . i would not do anything drastic like jb or anything .
1969 Dodge Charger
1969 Dodge Superbee
[Re: SkynyrdTim]
#915977
01/28/11 05:22 PM
01/28/11 05:22 PM
Posts: 15,487 Florida
scratchnfotraction
use one of the new style gasket on it
get it at the dealership parts counter
around 20$
kinda thick with o-ring rib on both side,it does not crush,DO NOT OVER TORQUE THE PAN BOLTS! it will strip the threds out...the gasket does not cruch and its re-usable
make sure the pan rail is in good shaped and not warped/puckerd at the bolt holes
hammer dolly them flat if need be first
are you sure its the pan leaking?
you have 2 seals right above the pan rail(shift selector/throttle pressure valve linkage) that will leak and drail down on to the pan rail
the lines can leak as the brass fittings some times cracks
the NSS switch can leak
the low revs pivot pin can leak,its at the rear of the case and tail housing
I degreese/wash them down good with brake clean,throw a hand full of baby powder around all the palces it leaks
this will pin point where it is leaking real ez
if you have done the pan that many times,with a new pan,I would wager its something else leaking
and your right it does make a kool car look junky when it drippys
cast alum pans are another good way to seal up a alum case tranz
good luck
[Re: SkynyrdTim]
#915980
01/28/11 05:52 PM
01/28/11 05:52 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
I'm tired of my tranny cover leaking. I bought a new cover and it still leaks. I've tried a cork gasket, rubber gasket and even tried two of each gasket! I've tried it with the spray tack with no luck.
I now want to bond it to the tranny FOREVER! Tell me what to use and I'll do it! I know this isn't the brightest idea, but I can't take it any more. Nothing makes a classic car look crappier than fluid leaking on the ground every time you park it! HELP!
Sorry but you just can't do that , the trans need to be serviced . I'll second are you sure it's the pan , gravity is a funny thing . Ther are 3 leak points ABOVE the pan , remember that gravity thing ??? The dipstick tube , the seal for the shift shaft and the pin for the rear band are all places that can leak and you'll think it's the pan ...
[Re: okie]
#915985
01/28/11 11:31 PM
01/28/11 11:31 PM
Posts: 17,861 albany ny
05dakota
albany ny
[Re: quick77rt ]
#915991
01/29/11 03:44 PM
01/29/11 03:44 PM
Posts: 13,604 md
mopars4ever
md
Didnt know the neon pans were a problem.
They are if you try to use a gasket. Try one and get back with me on your success. The autozone filter kit I bought had a rubber gasket and it leaked almost immediately. Then I tried a cork and it lasted a week or two. Then I used the Right Stuff and not a drop. I talked to a Dodge dealer tech and he said that they only use sealer on the neon trans pans. I never was a RTV sealer type of guy since it always seems messy and I always worried about some getting in places it shouldn`t be. I still use a gasket if possible but the neon was the exception.
[Re: Todd]
#915994
01/30/11 11:40 AM
01/30/11 11:40 AM
quick77rt
Parts Problem
Parts Problem
I looked yesterday, no gasket was used, just the ultra black and I think I let it sit overnight before filling. As I mentioned many dont use a gasket these days, a concept alot of us cant think about. I do know as thin and frail as the newer pans are and as good as the factory seal is its very easy to warp them when removing and get caught up trying to get them right on re-install. But im glad I didnt go the gasket way...
