What can I use to seal my tranny cover FOREVER? #915975
01/28/11 05:09 PM
01/28/11 05:09 PM
Scituate, RI
SkynyrdTim Offline OP
Scituate, RI
I'm tired of my tranny cover leaking. I bought a new cover and it still leaks. I've tried a cork gasket, rubber gasket and even tried two of each gasket! I've tried it with the spray tack with no luck.
I now want to bond it to the tranny FOREVER! Tell me what to use and I'll do it! I know this isn't the brightest idea, but I can't take it any more. Nothing makes a classic car look crappier than fluid leaking on the ground every time you park it! HELP!
Re: What can I use to seal my tranny cover FOREVER? [Re: SkynyrdTim] #915976
01/28/11 05:20 PM
01/28/11 05:20 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Are you sure it is leak from the pan ?
maybee comming from plug inside the bell for kick down lever shaft .
Or maybee the case has a crack or the vent is plugged .
i work on subaru cars and the factory puts the pans on with this pink factory trans silione type sealer and let me tell you if you use that you could take the bolts out and drive forever after it sets up .
i would not do anything drastic like jb or anything .
1969 Dodge Charger 1969 Dodge Superbee
Re: What can I use to seal my tranny cover FOREVER? [Re: SkynyrdTim] #915977
01/28/11 05:22 PM
01/28/11 05:22 PM
scratchnfotraction Offline
use one of the new style gasket on it
get it at the dealership parts counter
around 20$
kinda thick with o-ring rib on both side,it does not crush,DO NOT OVER TORQUE THE PAN BOLTS! it will strip the threds out...the gasket does not cruch and its re-usable
make sure the pan rail is in good shaped and not warped/puckerd at the bolt holes
hammer dolly them flat if need be first
are you sure its the pan leaking?
you have 2 seals right above the pan rail(shift selector/throttle pressure valve linkage) that will leak and drail down on to the pan rail
the lines can leak as the brass fittings some times cracks
the NSS switch can leak
the low revs pivot pin can leak,its at the rear of the case and tail housing
I degreese/wash them down good with brake clean,throw a hand full of baby powder around all the palces it leaks
this will pin point where it is leaking real ez
if you have done the pan that many times,with a new pan,I would wager its something else leaking
and your right it does make a kool car look junky when it drippys
cast alum pans are another good way to seal up a alum case tranz
good luck
Re: What can I use to seal my tranny cover FOREVER? [Re: SkynyrdTim] #915978
01/28/11 05:30 PM
01/28/11 05:30 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
"What can I use to seal my tranny cover FOREVER?"
A four speed.
Re: What can I use to seal my tranny cover FOREVER? [Re: Hugh Jorgan] #915979
01/28/11 05:45 PM
01/28/11 05:45 PM
thats a good one
Re: What can I use to seal my tranny cover FOREVER? [Re: SkynyrdTim] #915980
01/28/11 05:52 PM
01/28/11 05:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sorry but you just can't do that , the trans need to be serviced . I'll second are you sure it's the pan , gravity is a funny thing . Ther are 3 leak points ABOVE the pan , remember that gravity thing ??? The dipstick tube , the seal for the shift shaft and the pin for the rear band are all places that can leak and you'll think it's the pan ...
Re: What can I use to seal my tranny cover FOREVER? [Re: JohnRR] #915981
01/28/11 06:39 PM
01/28/11 06:39 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
I was at that same frustration level after several gaskets and a cast aluminum pan, replaced the dipstick with the Chebby style - Finally figured out with some spray cleaner and a bright halogen light that the tail shaft gasket right above the back of the pan was seeping and running all the way around the pan lip to drip off the front of the pan . Got that fixed and put the pan back on with the silver Permatex silicone and no gasket- hasn't leaked a drop since...
Re: What can I use to seal my tranny cover FOREVER? [Re: Hugh Jorgan] #915982
01/28/11 07:16 PM
01/28/11 07:16 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
A four speed.
Re: What can I use to seal my tranny cover FOREVER? [Re: rabid scott] #915983
01/28/11 09:44 PM
01/28/11 09:44 PM
Race City USA Mooresville N.C...
Ts road runner Offline
mopar addict
mopar addict
SOUTHERN BORN-SOUTHERN BREED-SOUTHERN DEAD
Re: What can I use to seal my tranny cover FOREVER? [Re: Ts road runner] #915984
01/28/11 10:53 PM
01/28/11 10:53 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I have bought new pans and used all the different gaskets and took it to a tranny shop this last time and let them do it and a month later it is leaking again. Mine isn't leaking any where except the pan so I'm taking it back to the shop and let them try it again. The bottom of the tranny is straight and there isn't any cracks in it. So 1 more time for me.
Re: What can I use to seal my tranny cover FOREVER? [Re: okie] #915985
01/28/11 11:31 PM
01/28/11 11:31 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
jb weld?
Re: What can I use to seal my tranny cover FOREVER? [Re: 05dakota] #915986
01/29/11 12:07 AM
01/29/11 12:07 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Best pan gasket is the Mopar sandwich style. Can't over tighten it and it's reusable. No sealer needed.
Re: What can I use to seal my tranny cover FOREVER? [Re: stumpy] #915987
01/29/11 02:34 AM
01/29/11 02:34 AM
Scituate, RI
Scituate, RI
I may have more than one leak, but the pan is definitely leaking. I've taken the pan off at least five times in the eight years I've owned the car and the result is the same. It ALWAYS leaks when I put it back on. Very frustrating.
As for servicing the tranny, I rebuilt it two years ago, so I shouldn't have any problems for awhile. My plan is to do a fluid and filter change the same time I seal the pan for good. I only drive the car about 1K a year, so I won't need a new filter for a long time.
As for you 4 speed guys, I'll stick with my 727 Torqueflite, thank you. It shifts flawlessly and saves wear and tear on my left leg and right arm! Big selling point when your body's starting to crap out on you!
Thanks for all the input. I did consider JB Weld, but I would have to make up a big batch of it and work fast! That $20 gasket might be worth a shot. Can't hurt at this point. Thanks again!
Re: What can I use to seal my tranny cover FOREVER? [Re: SkynyrdTim] #915988
01/29/11 04:15 AM
01/29/11 04:15 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I COULDN`T GET THE PAN TO SEAL ON MY NEON UNTIL I USED THIS STUFF. http://www.permatex.com/brand_right_stuff.htm
Re: What can I use to seal my tranny cover FOREVER? [Re: mopars4ever] #915989
01/29/11 04:49 AM
01/29/11 04:49 AM
BDW Online content
BDW  Online Content
I was in same boat, changed pan gasket 3 times till I figure out it was leaking from 3 other places and making it look like the pan gasket was the problem.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: What can I use to seal my tranny cover FOREVER? [Re: BDW] #915990
01/29/11 05:45 AM
01/29/11 05:45 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I recently did the first rec trans service on our 05 and the simple autozone filter and ultra black rtv, dont remember if it even had a gasket in the box. Maybe 10k ago and not a damp spot to be seen.
Alot of the newer trans ive serviced only have rtv of some sort or another and many no gasket at all.
Didnt know the neon pans were a problem.
Dont start on the dipstickless newer trans that you fill from the bottom of the pan....
Re: What can I use to seal my tranny cover FOREVER? [Re: quick77rt ] #915991
01/29/11 03:44 PM
01/29/11 03:44 PM
md
mopars4ever Offline
mopars4ever  Offline
md
They are if you try to use a gasket. Try one and get back with me on your success. The autozone filter kit I bought had a rubber gasket and it leaked almost immediately. Then I tried a cork and it lasted a week or two. Then I used the Right Stuff and not a drop. I talked to a Dodge dealer tech and he said that they only use sealer on the neon trans pans. I never was a RTV sealer type of guy since it always seems messy and I always worried about some getting in places it shouldn`t be. I still use a gasket if possible but the neon was the exception.
Re: What can I use to seal my tranny cover FOREVER? [Re: mopars4ever] #915992
01/29/11 09:08 PM
01/29/11 09:08 PM
Texas
TheHemi Offline
TheHemi  Offline
Texas
Works for everything!
Follow TheHEMI.com on TWITTER, FACEBOOK and/or MEWE !
Re: What can I use to seal my tranny cover FOREVER? [Re: TheHemi] #915993
01/29/11 10:16 PM
01/29/11 10:16 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I always use the Mopar gray sealant. Works better than any of the permatex stuff. Never had any leak problems. Needs no gasket.
Re: What can I use to seal my tranny cover FOREVER? [Re: Todd] #915994
01/30/11 11:40 AM
01/30/11 11:40 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I looked yesterday, no gasket was used, just the ultra black and I think I let it sit overnight before filling.
As I mentioned many dont use a gasket these days, a concept alot of us cant think about.
I do know as thin and frail as the newer pans are and as good as the factory seal is its very easy to warp them when removing and get caught up trying to get them right on re-install.
But im glad I didnt go the gasket way...
