1050 dominator overflowing #910330
01/21/11 04:34 PM
01/21/11 04:34 PM
bigfork mn
dragram440 Offline OP
bigfork mn
Last summer I kept having the same problem if my car would sit for a couple weeks or sometimes not even after it sat just out of the blue it would overflow out the top vent tube sometimes the front and sometimes the back neither one at the same time as the other. I would pull the needle and seat out clean it up good put it back in and then it wouldnt leak. It just seemed spuradic? Any ideas? Are my needle and seats bad? I have the fuel set at about 6-7 p.s.i. I have seen a few people with a hose between the front and back vent tubes why would that be? I should say the fuel only comes out when the pump is on.
67' charger 499 RB 10.57 at 127
Re: 1050 dominator overflowing [Re: dragram440] #910331
01/21/11 05:20 PM
01/21/11 05:20 PM
sg66mopar Offline
sg66mopar  Offline
My guess would be debris getting past the filter so the needle can't fully close. I've had this happen a couple times after I worked on the fuel lines. 400 GPM pumps =
Re: 1050 dominator overflowing [Re: sg66mopar] #910332
01/21/11 05:23 PM
01/21/11 05:23 PM
organ
maximum entropy Offline
organ
400 GPM pumps =
holy chet!! that's 24,000 gallons/ hour!!
Re: 1050 dominator overflowing [Re: maximum entropy] #910333
01/21/11 06:16 PM
01/21/11 06:16 PM
sg66mopar Offline
sg66mopar  Offline
400 GPM pumps =
Little boo-boo there maybe?
My irrigation pump doesn't even do that.
Re: 1050 dominator overflowing [Re: sg66mopar] #910334
01/21/11 06:25 PM
01/21/11 06:25 PM
bigfork mn
bigfork mn
Does anyone know why you would put a hose from the front to the rear vent? my vent tubes are about 1" from the bottom of the hood scoop.
Re: 1050 dominator overflowing [Re: dragram440] #910335
01/21/11 06:28 PM
01/21/11 06:28 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
To keep fuel from sloshing out the vents and down the carb
Re: 1050 dominator overflowing [Re: roadhazard] #910336
01/21/11 06:34 PM
01/21/11 06:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check your float level and your floats
Re: 1050 dominator overflowing [Re: Quicktree] #910337
01/21/11 06:39 PM
01/21/11 06:39 PM
bigfork mn
bigfork mn
Been through the floats and neadle and seats a handfull of times now.
Re: 1050 dominator overflowing [Re: dragram440] #910338
01/21/11 07:28 PM
01/21/11 07:28 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
I had a problem like this one time on the rear bowl. Turns out I didn't have a "notched" float and every time I installed it the float would get pinched between the bowl and the jets with extensions.
DC
Re: 1050 dominator overflowing [Re: dragram440] #910339
01/21/11 09:18 PM
01/21/11 09:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you messed with them that many times its time for
a new set of needle and seats and check your gauge
for accuracy
Re: 1050 dominator overflowing [Re: MR_P_BODY] #910340
01/21/11 10:49 PM
01/21/11 10:49 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Some saY to put a hose between the vent tubes with a notch cut out of the hose keeps the fuel from getting airated when running aram air hood and no air cleaner , i beleive they found this is because the more the fuel bubbles in the bowls the more the car would run lean on the big end of the track .
1969 Dodge Charger 1969 Dodge Superbee
Re: 1050 dominator overflowing [Re: cjs69mope] #910341
01/21/11 11:16 PM
01/21/11 11:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the reason they put a hose on there is to prevent fuel from sloshing when the car launches.
Re: 1050 dominator overflowing [Re: dragram440] #910342
01/21/11 11:26 PM
01/21/11 11:26 PM
detroit area
moderncylinder Offline
detroit area
what size hole is in the seat? meaning is it a .110? .120? etc???
maybe you have too much pressure with too large of a needle
how much power do you make and how fast is the car?
Re: 1050 dominator overflowing [Re: cjs69mope] #910343
01/21/11 11:31 PM
01/21/11 11:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As said already, the hose creates a taller stand pipe
so the fuel has to go that much higher to fall into
the carb... as for the bubbles... thats fuel hitting
the hot bowl... has nothing to do with the incoming
air flow
Re: 1050 dominator overflowing [Re: MR_P_BODY] #910344
01/22/11 12:15 AM
01/22/11 12:15 AM
UK
602heavy Offline
602heavy  Offline
UK
Always thought it was a lifting handle.
The tube across the two vents are fitted when running with no air cleaner , without the tube fuel will be syphoned out vent tube when making a run , the same princible as to how a booster/venturi operates , just remember to cut some holes in the tube.
As said , also eliminates fuel spillage on heavy launch.
Regards you're fuel spitting out of vent tube........i would put money on airated fuel supply , been there done it.
Re: 1050 dominator overflowing [Re: 602heavy] #910345
01/22/11 08:58 PM
01/22/11 08:58 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
This is what I learned .......... it would siphon out at speed.
I don't know if I was ever that fast where it would be a problem , but the " monkey see - monkey " do thing is sometimes too powerful to ignore.
It does make sense on paper.
Re: 1050 dominator overflowing [Re: tubtar] #910346
01/23/11 12:44 PM
01/23/11 12:44 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
I run the vent tubes on mine to keep the fuel from splashing on launch. I tested my car on my road and with no hood and dual dominators, it would splash fuel on a launch. This vent hose cured that problem.
Re: 1050 dominator overflowing [Re: SCDaytona] #910347
01/23/11 12:58 PM
01/23/11 12:58 PM
Q
Quicktree Offline
Quicktree  Offline
Q
usually if that happens the fuel level is to high. but yes thats what they are used for. if it's squirting out the top there is something wrong with floats, fuel level, pressure.
Re: 1050 dominator overflowing [Re: dc426] #910348
01/23/11 01:10 PM
01/23/11 01:10 PM
Santa Rosa,CA USA
67dodgeracer Offline
Santa Rosa,CA USA
DC [/quote
This happened to me as well.I have notched floats but they were still hanging up on my long plastic jet extensions when I turned the pump on to fill the carb.Fixed it by turning the pump on and shutting it off quickly,doing this until the bowls are full.This has kept the float from sticking and sending fuel out the vent tubes.Try it and see if it works.
Re: 1050 dominator overflowing [Re: 67dodgeracer] #910349
01/23/11 01:12 PM
01/23/11 01:12 PM
Santa Rosa,CA USA
Santa Rosa,CA USA
I just read your post a little more and saw it comes out the front also.Guess that would eliminate my suggestion
