1050 dominator overflowing
#910330
01/21/11 04:34 PM
01/21/11 04:34 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Last summer I kept having the same problem if my car would sit for a couple weeks or sometimes not even after it sat just out of the blue it would overflow out the top vent tube sometimes the front and sometimes the back neither one at the same time as the other. I would pull the needle and seat out clean it up good put it back in and then it wouldnt leak. It just seemed spuradic? Any ideas? Are my needle and seats bad? I have the fuel set at about 6-7 p.s.i. I have seen a few people with a hose between the front and back vent tubes why would that be? I should say the fuel only comes out when the pump is on.
67' charger 499 RB
10.57 at 127
Re: 1050 dominator overflowing
[Re: maximum entropy]
#910333
01/21/11 06:16 PM
01/21/11 06:16 PM
Posts: 1,288 Oregon
sg66mopar
400 GPM pumps =
holy chet!! that's 24,000 gallons/ hour!!
Little boo-boo there maybe?
My irrigation pump doesn't even do that.
[Re: sg66mopar]
#910334
01/21/11 06:25 PM
01/21/11 06:25 PM
dragram440
bigfork mn
Does anyone know why you would put a hose from the front to the rear vent? my vent tubes are about 1" from the bottom of the hood scoop.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#910335
01/21/11 06:28 PM
01/21/11 06:28 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
To keep fuel from sloshing out the vents and down the carb
[Re: Quicktree]
#910337
01/21/11 06:39 PM
01/21/11 06:39 PM
dragram440
bigfork mn
Been through the floats and neadle and seats a handfull of times now.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#910339
01/21/11 09:18 PM
01/21/11 09:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you messed with them that many times its time for a new set of needle and seats and check your gauge for accuracy
[Re: MR_P_BODY]
#910340
01/21/11 10:49 PM
01/21/11 10:49 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Some saY to put a hose between the vent tubes with a notch cut out of the hose keeps the fuel from getting airated when running aram air hood and no air cleaner , i beleive they found this is because the more the fuel bubbles in the bowls the more the car would run lean on the big end of the track .
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#910341
01/21/11 11:16 PM
01/21/11 11:16 PM
Quicktree
the reason they put a hose on there is to prevent fuel from sloshing when the car launches.
[Re: cjs69mope]
#910343
01/21/11 11:31 PM
01/21/11 11:31 PM
MR_P_BODY
As said already, the hose creates a taller stand pipe so the fuel has to go that much higher to fall into the carb... as for the bubbles... thats fuel hitting the hot bowl... has nothing to do with the incoming air flow
[Re: MR_P_BODY]
#910344
01/22/11 12:15 AM
01/22/11 12:15 AM
Posts: 1,200 UK
602heavy
UK
Always thought it was a lifting handle. The tube across the two vents are fitted when running with no air cleaner , without the tube fuel will be syphoned out vent tube when making a run , the same princible as to how a booster/venturi operates , just remember to cut some holes in the tube. As said , also eliminates fuel spillage on heavy launch. Regards you're fuel spitting out of vent tube........i would put money on airated fuel supply , been there done it.
[Re: 602heavy]
#910345
01/22/11 08:58 PM
01/22/11 08:58 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
This is what I learned .......... it would siphon out at speed. I don't know if I was ever that fast where it would be a problem , but the " monkey see - monkey " do thing is sometimes too powerful to ignore. It does make sense on paper.
[Re: SCDaytona]
#910347
01/23/11 12:58 PM
01/23/11 12:58 PM
Quicktree
I run the vent tubes on mine to keep the fuel from splashing on launch. I tested my car on my road and with no hood and dual dominators, it would splash fuel on a launch. This vent hose cured that problem.
usually if that happens the fuel level is to high. but yes thats what they are used for. if it's squirting out the top there is something wrong with floats, fuel level, pressure.
[Re: dc426]
#910348
01/23/11 01:10 PM
01/23/11 01:10 PM
Posts: 391 Santa Rosa,CA USA
67dodgeracer
Santa Rosa,CA USA
I had a problem like this one time on the rear bowl. Turns out I didn't have a "notched" float and every time I installed it the float would get pinched between the bowl and the jets with extensions. DC [/quote
This happened to me as well.I have notched floats but they were still hanging up on my long plastic jet extensions when I turned the pump on to fill the carb.Fixed it by turning the pump on and shutting it off quickly,doing this until the bowls are full.This has kept the float from sticking and sending fuel out the vent tubes.Try it and see if it works.
