Resticted exhaust causing plugs to foul? #90886
07/19/08 05:51 PM
07/19/08 05:51 PM
Western New York since 2000
dart44072 Offline OP
super gas
super gas
After reading a post about exhaust restriction, I got to thinking about my problem. No matter what I've tried(and I've tried everything ) my fresh 360 in my 64 Valiant keeps fouling plugs and runs like crap.Runs so bad i cant get any adjustments to make a difference. I have spitfire headers but the exhaust shop kinda screwed up my 2 1/4"pipes . It's pretty tight up by the engine area and they may have put a few to tight restictions and it's not mandrel bent. Does anyone have any "real life " experience with exhaust restriction? What would the symptoms be? Thanks,
Dave.............
Re: Resticted exhaust causing plugs to foul? [Re: dart44072] #90887
07/19/08 06:01 PM
07/19/08 06:01 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Sounds more like a carburetor jetting problem.
Re: Resticted exhaust causing plugs to foul? [Re: Neil] #90888
07/19/08 06:06 PM
07/19/08 06:06 PM
super gas
super gas
I've tried 5 carbs from a new 600 eddy, a used 600 eddy, a new 750 eddy a new 750 Holley and a Thermoquad. All had the same results.
Re: Resticted exhaust causing plugs to foul? [Re: Neil] #90889
07/19/08 06:15 PM
07/19/08 06:15 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Sounds like another problem to me if it fouling plugs.
Re: Resticted exhaust causing plugs to foul? [Re: MoparforLife] #90890
07/19/08 06:28 PM
07/19/08 06:28 PM
super gas
super gas
I tried another dist. and another intake. I've set the timing just about anywhere it'll keep running and cant get it to stop fouling plugs. I have 3 sets of plugs that i keep changing in and out. What a pain in the a**!!!! I just thought maybe the exhaust was choking out the engine? But probably wouldn't effect it that much at idle.
Re: Resticted exhaust causing plugs to foul? [Re: dart44072] #90891
07/19/08 06:36 PM
07/19/08 06:36 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
They are fuel fouled ? ... waaaay too cold of plugs ??
Re: Resticted exhaust causing plugs to foul? [Re: dOc !] #90892
07/19/08 06:52 PM
07/19/08 06:52 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If it was possible for an exhaust system to foul plugs then the stock 273 a-body cars would be in trouble. Manifolds don't come any more restrictive than those things.
Re: Resticted exhaust causing plugs to foul? [Re: Neil] #90893
07/19/08 07:01 PM
07/19/08 07:01 PM
super gas
super gas
Plugs are black powder coated.
Re: Resticted exhaust causing plugs to foul? [Re: dart44072] #90894
07/20/08 12:30 AM
07/20/08 12:30 AM
choke staying on too long. EDIT. or rings aren't seated. where is your timing at?
Re: Resticted exhaust causing plugs to foul? [Re: RapidRobert] #90895
07/20/08 12:58 AM
07/20/08 12:58 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
To test ...put in a set of 3 step HOTTER plugs.
Re: Resticted exhaust causing plugs to foul? [Re: dOc !] #90896
07/20/08 06:47 AM
07/20/08 06:47 AM
Maybe your ignition is not gettin the rite voltage ????
Re: Resticted exhaust causing plugs to foul? #90897
07/20/08 08:49 AM
07/20/08 08:49 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
To test for exhaust restriction
1. Connect vacuum gauge to manifold vacuum and tach to the engine.
2. Gradually accelerate engine from idle to 2000 RPM
3. Note vacuum reading.
4. Maintain 2000 RPM for 10 seconds or longer while observing vacuum gauge.
If exhaust system is restricted, vacuum reading will gradually decrease.
Re: Resticted exhaust causing plugs to foul? [Re: convx4] #90898
07/20/08 09:47 AM
07/20/08 09:47 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
you shure about that one...i use a manometer
Re: Resticted exhaust causing plugs to foul? [Re: mark7171] #90899
07/20/08 09:53 AM
07/20/08 09:53 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Are you running a electric fuel pump?
Re: Resticted exhaust causing plugs to foul? #90900
07/20/08 09:58 AM
07/20/08 09:58 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
This is the direction I would head in. You may have a weak spark. Try a different coil. Bypass your ballast resistors to see if that changes things. i had this happen to me along time ago and after changing almost all the parts my dad comes over and says did you check the coil? Uh, no dad. Stuck an old used coil on and it ran great.
Re: Resticted exhaust causing plugs to foul? [Re: dmerc] #90901
07/20/08 10:10 AM
07/20/08 10:10 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This may sound odd but have you checked to make sure you have the +,- wires to the coil hooked up correctly? It's possible to have them backwards and run. This will give you symtoms similar to what you are expreiencing.
Re: Resticted exhaust causing plugs to foul? [Re: stumpy] #90902
07/20/08 10:34 AM
07/20/08 10:34 AM
super gas
super gas
The electrical part of it I haven't really checked. I'll play around with that stuff Monday afternoon. Thanks for brainstorming for possible problems. I'll listen to any thoughts
Dave.........ps. NO electric fuel pump.
