Resticted exhaust causing plugs to foul?
#90886
07/19/08 05:51 PM
07/19/08 05:51 PM
Posts: 574 Western New York since 2000
dart44072
super gas
super gas
After reading a post about exhaust restriction, I got to thinking about my problem. No matter what I've tried(and I've tried everything ) my fresh 360 in my 64 Valiant keeps fouling plugs and runs like crap.Runs so bad i cant get any adjustments to make a difference. I have spitfire headers but the exhaust shop kinda screwed up my 2 1/4"pipes . It's pretty tight up by the engine area and they may have put a few to tight restictions and it's not mandrel bent. Does anyone have any "real life " experience with exhaust restriction? What would the symptoms be? Thanks, Dave.............
Re: Resticted exhaust causing plugs to foul?
[Re: dart44072]
#90894
07/20/08 12:30 AM
07/20/08 12:30 AM
RapidRobert
choke staying on too long. EDIT. or rings aren't seated. where is your timing at?
[Re: dOc …]
#90896
07/20/08 06:47 AM
07/20/08 06:47 AM
Maybe your ignition is not gettin the rite voltage ????
[Re: convx4]
#90898
07/20/08 09:47 AM
07/20/08 09:47 AM
Posts: 1,261 ILL
mark7171
ILL
To test for exhaust restriction 1. Connect vacuum gauge to manifold vacuum and tach to the engine. 2. Gradually accelerate engine from idle to 2000 RPM 3. Note vacuum reading. 4. Maintain 2000 RPM for 10 seconds or longer while observing vacuum gauge.
If exhaust system is restricted, vacuum reading will gradually decrease.
you shure about that one...i use a manometer
#90900
07/20/08 09:58 AM
07/20/08 09:58 AM
Posts: 1,061 New Mexico
dmerc
New Mexico
This is the direction I would head in. You may have a weak spark. Try a different coil. Bypass your ballast resistors to see if that changes things. i had this happen to me along time ago and after changing almost all the parts my dad comes over and says did you check the coil? Uh, no dad. Stuck an old used coil on and it ran great.
