dropping in engine and trans #90772
07/19/08 12:19 PM
07/19/08 12:19 PM
Camarillo, CA.
P
preston Offline OP
preston  Offline OP
P
Camarillo, CA.
Hi, Im ready to install the engine and trans (340/727) into my 69 dart. I wanted to know which way you found to be the best way. Engine and trans together or seperate? Thanks Bob
Re: dropping in engine and trans [Re: preston] #90773
07/19/08 12:24 PM
07/19/08 12:24 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Together is the best way, you will not the car up pretty high. You may find it easier with some
helper moving the tail shaft around a bit.
Then a jack under the trans.
Re: dropping in engine and trans [Re: preston] #90774
07/19/08 12:26 PM
07/19/08 12:26 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
if your going to do both at once have someone else with you besides your wife!!!! is your trannie fluid in?
Re: dropping in engine and trans [Re: ngpSatellite] #90775
07/19/08 12:32 PM
07/19/08 12:32 PM
RapidRobert Online content
RapidRobert  Online Content
spring for a engine tilter with the (4) chains & take off the hand crank as it can hit your cherry picker arm usually at the most inopportune time. & weld on a nut & use an impact gun to change the tilt. Go slow, making dents/dings/scratches will make you pi$$ed for days afterard. & DEFINITELY have a helper.
Re: dropping in engine and trans [Re: RapidRobert] #90776
07/19/08 12:45 PM
07/19/08 12:45 PM
Camarillo, CA.
P
preston Offline OP
preston  Offline OP
P
Camarillo, CA.
I do have the engine tilter with my hoist. Thanks for the heads up on taking the handle off, i can see that could be a problem. It seems the best way to go is engine and trans together. Thanks for all the help. Bob
Re: dropping in engine and trans [Re: preston] #90777
07/19/08 01:05 PM
07/19/08 01:05 PM
& I always drop the center steering link. & maybe even the steering box & column. It always seems to go MUCH better when I do. One of my personal pet peeves is I just don't like the eng bumping anything on the way in. more work but when I'm done I know I did it RIGHT. PRICELESS
Re: dropping in engine and trans [Re: preston] #90778
07/19/08 01:08 PM
07/19/08 01:08 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Or maybe just turn the load leveler (tilter) so the handle is away from the lift.
Re: dropping in engine and trans [Re: Fab64] #90779
07/19/08 01:54 PM
07/19/08 01:54 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
drop the k member and set the motor on it and then slide the hole thing under the car and use the cherry picker to lift the car up and drop it down , no dings nicks or messups.
Re: dropping in engine and trans [Re: wildfish72] #90780
07/19/08 02:28 PM
07/19/08 02:28 PM
Niagara, Ontario Canada
mrpatel Offline
mrpatel  Offline
do you have alluminum heads? if so are you still planning on installing them together? I will be doing the same next week and have some concerns bolting all that weight directly to 4 bolts on my heads.
Re: dropping in engine and trans [Re: preston] #90781
07/19/08 02:35 PM
07/19/08 02:35 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Crazy as it sounds... ...raise the rear of the car. It will cut down on the angle that the trans and engine would need to be to slide in.
Try it.
Re: dropping in engine and trans [Re: Chi_Town_Runner] #90782
07/19/08 02:40 PM
07/19/08 02:40 PM
mrpatel Offline
mrpatel  Offline
Thats what we did when we pulled the engine and trans out last week. Front of the car on the ground, the rear raised up enough to get underneath.
Re: dropping in engine and trans [Re: mrpatel] #90783
07/19/08 06:52 PM
07/19/08 06:52 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
that how i
use to pull all my motors out.
