Re: dropping in engine and trans
[Re: ngpSatellite]
#90775
07/19/08 12:32 PM
07/19/08 12:32 PM
RapidRobert
spring for a engine tilter with the (4) chains & take off the hand crank as it can hit your cherry picker arm usually at the most inopportune time. & weld on a nut & use an impact gun to change the tilt. Go slow, making dents/dings/scratches will make you pi$$ed for days afterard. & DEFINITELY have a helper.
