Re: TORSION BAR REMOVAL...WHAT DO I NEED TO KNOW *DELETED*
[Re: mopar rookie]
#902093
01/11/11 04:04 PM
01/11/11 04:04 PM
Posts: 2,782 USA
JoesMopar
USA
Re: TORSION BAR REMOVAL...WHAT DO I NEED TO KNOW *DELETED* *DELETED* *DELETED*
[Re: hemigod426]
#902096
01/11/11 04:11 PM
01/11/11 04:11 PM
Posts: 2,782 USA
JoesMopar
USA
[Re: JoesMopar]
#902097
01/11/11 04:19 PM
01/11/11 04:19 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
I've never had that problem, and I've done it many times. The torsion bar is much stronger than any pressure applied from a pair of vise grips. Maybe you guys can tell him (and me) the correct way to get them out without buying the "one time tool" or whatever it's called.
Remove the nut for the pivot shaft and the strut on the lower control arm, after removing the tension off the T bar, and pry the control arm back with a long bar. Visegrips will put marks in the T bar and could cause it to break according to the internet and the factory service manual .
[Re: JoesMopar]
#902098
01/11/11 04:31 PM
01/11/11 04:31 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
You have to loosen the adjusting nut in the LCA all the way down to take the pressure off. Get the car in the air, remove the retaining ring in the back of the torsion bar, take a big pair of vise grips or anything "Craftsman" (lifetime warranty....), clamp it on the torsion bar and bang it out.
This idea WILL work, and I agree that it may never produce any ill effects, but it isnt good advice. I have used vice grips, pipe wrenches and Channel locks to remove T bars. I have also removed them by pulling the LCAs as well. I have never had a torsion bar fail, but it can happen. On cars I dismantle, I'll use a pipe wrench. On the Charger and Frankenduster, I just pull the control arm to be safe.
[Re: hemigod426]
#902106
01/11/11 08:29 PM
01/11/11 08:29 PM
Posts: 2,782 USA
JoesMopar
USA
[Re: hemigod426]
#902110
01/11/11 09:46 PM
01/11/11 09:46 PM
Posts: 2,782 USA
JoesMopar
USA
