73 satellite gas tank questions UPDATE sender ?
#896376
01/04/11 10:43 PM
01/04/11 10:43 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
Hey guys,
I just dropped the old full of rust tank from the 73 today and had a couple questions.
I noticed the tank had 4 vents on it with lines that just go right to some kind of block right above the tank. I didn't look hard, but it looks like they go just to that and thats it. is that right?
From the sending unit it I have one line that comes out and goes up front. 5/16 it seems (original 318 car) and the connector for the gauge I am assuming and then a ground strap.
I thought there was a return as well? or am I confused?
I am quite sure if there was any kind of emissions type stuff on this car it is long gone as my dad used to race street/strip this car in the 80's when I was in high school.
anyway, I am making this car a driver in every sense. Not a show car. It is for my son to use as well. So I don't care about anything other than a working gauge and fuel getting up front.
so can I just get the replacment tank, hook up the 4 vents back to those old lines, put in a new fill tube grommet and ride? ofcourse run new fuel line up front.
if I am going to run new line up front I should probably get a sender with a 3/8 pickup right? this car will see either a 440 or possibly a 493 in about 6 months. there is no difference in the senders other than the line size right?
I attached a pic of the car just because it is finally getting somewhere. promised this to be ready for my sons high school graduation as the last time it was on the road was my graduation in 88, but I am a little behind as he is in college now. LOL
Thanks guys and sorry this was so long.
Sender is measuring 74.4 ohms empty and if I flip the tank over it reads 7.5 ohms full. I was told 10-73. Do I have to tweek it or will this work?
Re: 73 satellite gas tank questions
[Re: RonP]
#896377
01/04/11 10:50 PM
01/04/11 10:50 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
I just put in a new fuel line to the fuel pump, completly did away with emmisions parts, mine also was missing most of it. If you are planning on going with electric fuel pump, you may want to run a return line.
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: DaytonaTurbo]
#896382
01/05/11 10:21 AM
01/05/11 10:21 AM
RonP
Jacksonville, NC
I put a 73 gas tank in my 74. Those 4 hoses on the top, I just capped them off, then had to run a vented gas cap so vacuum would not build up in the tank. I capped off the vapor cannister and junked it as well. Was originally from a 318 car so it never had the provisions for the vapor seperator. I have heard of some guys soddering in a 3/8" fuel pickup line into their original 5/16" pickup assy to do it on the cheap. Have read enough stories from guys on here having trouble with the aftermarket fuel senders that modding a stocker doesn't sound like a bad idea.
Tristan, I figured you would post and I appreciate it. No reusing the stock sender as it is probably now the most rusted part in my garage. It was terrible. This car hasn't had fuel put in it since 1988. I hope the aftermarket one isn't junk. Thanks for the tips.
Ron
[Re: IMGTX]
#896384
01/05/11 11:50 AM
01/05/11 11:50 AM
RonP
Jacksonville, NC
Just a note. Varnish will look like rust. I had a guy give me a tank he swore was rusted and a little carb cleaner and it was good as new.
Thanks. This ones is bad and had a hole as well. I emptied large chunks of rusty crap out of it.
just ordered all the replacement stuff a few minutes ago.
[Re: DaytonaTurbo]
#896386
01/10/11 10:23 PM
01/10/11 10:23 PM
RonP
Jacksonville, NC
Good luck with it. I bought a new spectra premium gas tank for my car. Another 73 tank, still sitting new in the box, will be in the car by spring. My 73 tank that I swapped in is pretty beat and leaks around the fuel neck because I accidentally wallowed out that hole trying to get the neck out 8 years ago.
Also, test out your aftermarket fuel sender with your multimeter before you install the tank. Put the sender in and attach the multimeter, take a reading. Then flip the gas tank over and take another reading. You want close to 10ohms full/73 empty. Don't be too surprised if you need to tweak the rod going to the float to get the readings within range.
