Better (brighter/lower temp) dash bulb than a 57?
#888435
12/26/10 02:06 AM
12/26/10 02:06 AM
Posts: 7,052 Madera, CA.
MowP4rsn
Madera, CA.
I've got the left side of my dash dark, and it is a PITA to get out the dash what with the pot-metal assembly/framing, so I don't want to screw around with this stuff any time soon after I fix it. Here's the specs on the 57 bulb # Trade No.: 57 # Design Volts: 14.0 # Amps: 0.24 # Rated Average Life Volts per Hour: 500 # Filament Type: C-2V # Bulb Type: G-4 1/2 # Base Type: Miniature Bayonet Anyhoo, do any of you guys know of a replacement bulb that will are a better substitute, keeping in mind that the base has to be the mini-bayonet style? ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: Better (brighter/lower temp) dash bulb than a 57?
[Re: MowP4rsn]
#888437
12/27/10 04:02 AM
12/27/10 04:02 AM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
I use the Blue LED's in my dash and Autometer gauges. Work great!! whitegauges.net
Here is my tach with only one 4 led bulb,
[Re: CUUDAK]
#888439
12/28/10 01:20 AM
12/28/10 01:20 AM
MowP4rsn
Madera, CA.
Ooooooooo nice! Do you remember how much the bulb cost you?
[Re: MowP4rsn]
#888440
12/28/10 01:32 AM
12/28/10 01:32 AM
MowP4rsn
Madera, CA.
They list $5 ![](/ubbthreads/images/graemlins/shock.gif)
However, there is a bulb that looks like it might work better for the application I'm asking about as it appears to throw more light to the side, and it's about $2 per bulb It has a concave lense ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) ![](http://www.ledlight.com/images/34214-ba9s-concave-led-light.jpg)
