Better (brighter/lower temp) dash bulb than a 57? #888435
12/26/10 02:06 AM
12/26/10 02:06 AM
Madera, CA.
MowP4rsn Offline OP
MowP4rsn  Offline OP
Madera, CA.
I've got the left side of my dash dark, and it is a PITA to get out the dash what with the pot-metal assembly/framing, so I don't want to screw around with this stuff any time soon after I fix it.
Here's the specs on the 57 bulb
# Trade No.: 57
# Design Volts: 14.0
# Amps: 0.24
# Rated Average Life Volts per Hour: 500
# Filament Type: C-2V
# Bulb Type: G-4 1/2
# Base Type: Miniature Bayonet
Anyhoo, do any of you guys know of a replacement bulb that will are a better substitute, keeping in mind that the base has to be the mini-bayonet style?
Re: Better (brighter/lower temp) dash bulb than a 57? [Re: MowP4rsn] #888436
12/26/10 02:13 AM
12/26/10 02:13 AM
Madera, CA.
MowP4rsn Offline OP
MowP4rsn  Offline OP
Madera, CA.
2 listings I found that are intriguing are This one at $5.99
OR this 4 LED unit at $6.49
Re: Better (brighter/lower temp) dash bulb than a 57? [Re: MowP4rsn] #888437
12/27/10 04:02 AM
12/27/10 04:02 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
I use the Blue LED's in my dash and Autometer gauges. Work great!! whitegauges.net
Here is my tach with only one 4 led bulb,
Re: Better (brighter/lower temp) dash bulb than a 57? [Re: CUUDAK] #888438
12/27/10 09:11 AM
12/27/10 09:11 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I'm looking for LEDs to replace the 57's in my dash lights. I'm looking here:
http://www.ledlight.com/ba9s-short-round-led-light.aspx
I'd like to find someone that has already done this and has the experience. There are lots of choices...
Re: Better (brighter/lower temp) dash bulb than a 57? [Re: CUUDAK] #888439
12/28/10 01:20 AM
12/28/10 01:20 AM
Madera, CA.
MowP4rsn Offline OP
MowP4rsn  Offline OP
Madera, CA.
Ooooooooo nice! Do you remember how much the bulb cost you?
Re: Better (brighter/lower temp) dash bulb than a 57? [Re: MowP4rsn] #888440
12/28/10 01:32 AM
12/28/10 01:32 AM
Madera, CA.
MowP4rsn Offline OP
MowP4rsn  Offline OP
Madera, CA.
They list $5
However, there is a bulb that looks like it might work better for the application I'm asking about as it appears to throw more light to the side, and it's about $2 per bulb It has a concave lense
Re: Better (brighter/lower temp) dash bulb than a 57? [Re: TooMany62s] #888441
12/28/10 01:35 AM
12/28/10 01:35 AM
Madera, CA.
MowP4rsn Offline OP
MowP4rsn  Offline OP
Madera, CA.
Yeah, some good choices there, thanks for the link!
