Re: Jeep Grand Cherrokee won't stay running
[Re: 70HemiGTX]
#887406
12/24/10 07:11 PM
12/24/10 07:11 PM
RapidRobert
any recent changes? Happened all of a sudden? take out idle mixture screws and shoot a 2 second blast of starting fluid in each one then reinstall the screws (count the turns to get em back the same). classic vacuum leak symptom. Holler when you find something
[Re: 70HemiGTX]
#887408
12/24/10 07:17 PM
12/24/10 07:17 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Check your battery. It might be battery time.
Carl Kessel
[Re: 70HemiGTX]
#887409
12/24/10 07:47 PM
12/24/10 07:47 PM
RapidRobert
didn't realize it was FI. I'm totally lost on the new stuff and anything I might suggest would only add to the prob. Good luck w it.
[Re: CKessel]
#887410
12/24/10 07:57 PM
12/24/10 07:57 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
thats how mine acted when the batt was bad
[Re: CKessel]
#887414
12/25/10 01:58 AM
12/25/10 01:58 AM
Posts: 5,444 So Cal
Sinitro
So Cal
Good catch.. If the battery is weak when the idle drops down below 1K, the alternator's output drops.. And the battery does not have enough juice to keep the computer & ignition running.
I had that issue with my 98 Dakota..
Just my $0.02..
[Re: 70HemiGTX]
#887417
12/27/10 11:45 PM
12/27/10 11:45 PM
Posts: 553 DE
Ply72rr
DE
Had the battery out two weeks ago to replace the headlight bulb, but it was fine till just today. I'll check the battery better tomorrow. My wife said at first it was dead, but I jumped it and it ran fine. Even started on it's own after shutting it off.
We run into the no idle condition anytime one of the dodge vans in our fleet runs the battery down and needs a jump start. After conecting the jump cables I unplug the ECU for about 30 seconds and reconect it and then they idle normally.
[Re: Ply72rr]
#887419
12/28/10 09:43 AM
12/28/10 09:43 AM
Posts: 2,361 PA
70HemiGTX
PA
Only probem was that my wife drove the thing for about 2 weeks before it quit on her.
