Jeep Grand Cherrokee won't stay running #887405
12/24/10 06:57 PM
12/24/10 06:57 PM
PA
70HemiGTX Offline OP
PA
My 97 Jeep (318) won't stay running. As soon as you let off the pedal it stalls out. You have to keep the tach at about 1k to keep it running. Any suggestions? Gas tank is full.
Re: Jeep Grand Cherrokee won't stay running [Re: 70HemiGTX] #887406
12/24/10 07:11 PM
12/24/10 07:11 PM
any recent changes? Happened all of a sudden? take out idle mixture screws and shoot a 2 second blast of starting fluid in each one then reinstall the screws (count the turns to get em back the same). classic vacuum leak symptom. Holler when you find something
Re: Jeep Grand Cherrokee won't stay running [Re: RapidRobert] #887407
12/24/10 07:16 PM
12/24/10 07:16 PM
PA
PA
Fuel injected. Never thought of a vac. leak.
Re: Jeep Grand Cherrokee won't stay running [Re: 70HemiGTX] #887408
12/24/10 07:17 PM
12/24/10 07:17 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Check your battery. It might be battery time.
Carl Kessel
Re: Jeep Grand Cherrokee won't stay running [Re: 70HemiGTX] #887409
12/24/10 07:47 PM
12/24/10 07:47 PM
didn't realize it was FI.
I'm totally lost on the new stuff and anything I might suggest would only add to the prob. Good luck w it.
Re: Jeep Grand Cherrokee won't stay running [Re: CKessel] #887410
12/24/10 07:57 PM
12/24/10 07:57 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
thats how mine acted when the batt was bad
Re: Jeep Grand Cherrokee won't stay running [Re: Dakota_Don] #887411
12/24/10 10:46 PM
12/24/10 10:46 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Maybe idle air control valve.
Re: Jeep Grand Cherrokee won't stay running [Re: 70HemiGTX] #887412
12/24/10 10:57 PM
12/24/10 10:57 PM
Northwest
Four40mopar Offline
Four40mopar  Offline
Northwest
Did you recently change, disconect, or have the battery go dead? If so you need to reset the idle air control valve, to do this start by holding the rpms at 1000 or so and very slowly lower the rpms until the ecm can relearn the idle. This will take 3-5 min.
Re: Jeep Grand Cherrokee won't stay running [Re: Four40mopar] #887413
12/25/10 12:48 AM
12/25/10 12:48 AM
PA
PA
Had the battery out two weeks ago to replace the headlight bulb, but it was fine till just today. I'll check the battery better tomorrow. My wife said at first it was dead, but I jumped it and it ran fine. Even started on it's own after shutting it off.
Re: Jeep Grand Cherrokee won't stay running [Re: CKessel] #887414
12/25/10 01:58 AM
12/25/10 01:58 AM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
Good catch..
If the battery is weak when the idle drops down below 1K, the alternator's output drops..
And the battery does not have enough juice to keep the computer & ignition running.
I had that issue with my 98 Dakota..
Just my $0.02..
Re: Jeep Grand Cherrokee won't stay running [Re: Sinitro] #887415
12/25/10 03:47 AM
12/25/10 03:47 AM
Gig Harbor,WA
Commando66 Offline
Commando66  Offline
Gig Harbor,WA
Dirty throttle body? Happened on my 95 Ram occasionally.
Re: Jeep Grand Cherrokee won't stay running [Re: Commando66] #887416
12/27/10 11:11 PM
12/27/10 11:11 PM
PA
PA
New batter fixed it right up. Thanks guys!
Re: Jeep Grand Cherrokee won't stay running [Re: 70HemiGTX] #887417
12/27/10 11:45 PM
12/27/10 11:45 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
We run into the no idle condition anytime one of the dodge vans in our fleet runs the battery down and needs a jump start. After conecting the jump cables I unplug the ECU for about 30 seconds and reconect it and then they idle normally.
Re: Jeep Grand Cherrokee won't stay running [Re: Ply72rr] #887418
12/28/10 12:00 AM
12/28/10 12:00 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
My 96 did the same thing. Was the battery.
Re: Jeep Grand Cherrokee won't stay running [Re: Ply72rr] #887419
12/28/10 09:43 AM
12/28/10 09:43 AM
PA
PA
Only probem was that my wife drove the thing for about 2 weeks before it quit on her.
