glass tube fuses adaptor
#869301
12/02/10 05:54 AM
12/02/10 05:54 AM
Posts: 347 FRANCE, Paris
Chal340
FRANCE, Paris
I would like to buy this kind of adaptor to replace all glass tube fuses, do you know where I could buy them. Thanks
70 Challenger, A66, 340 ci
Re: glass tube fuses adaptor
[Re: stumpy]
#869303
12/02/10 04:40 PM
12/02/10 04:40 PM
Chal340
FRANCE, Paris
In USA yes but in France no, can you indicate me a store and i will buy them. Thanks
[Re: stumpy]
#869307
12/02/10 06:07 PM
12/02/10 06:07 PM
Chal340
FRANCE, Paris
We found a store that sold them ( http://jttproducts.com/showcase.shtml ), we bought a hundred, but it does not sell more. So if you know a store. I will be in the USA in L.A. and Las Vegas in April for the M.A.T.S., I'll buy 200 parts for our club.
[Re: stumpy]
#869308
12/04/10 06:37 PM
12/04/10 06:37 PM
gtx69
super gas
super gas
Local parts store electrical section.
Stumpy still waiting on your reply as to the name of a store that sells these.
[Re: gtx69]
#869313
12/04/10 11:16 PM
12/04/10 11:16 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I have update my fuse box years ago.I have another car im working on but i don't want to rewire that one leaving box stock.Would like something easy to switch back to stock.Then who sells the circut breaker type?
Yes, it is similar to the fuse pic in the OP, however it has a circuit breaker that will reset when overloaded, simply snaps inplace of the fuse.
[Re: sthemi]
#869314
12/04/10 11:36 PM
12/04/10 11:36 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...sthemi, is this the one/type you're talking about?
[Re: sthemi]
#869316
12/05/10 12:43 AM
12/05/10 12:43 AM
gtx69
super gas
super gas
There is also a circuit breaker type replacment for glass fuses, I used on in my 79 Truck...
Who sells them?
[Re: gtx69]
#869318
12/05/10 04:10 AM
12/05/10 04:10 AM
sthemi
Chicago Burbs
Not exactly the same, I bought them at Murray's, which is now O Reilly, about 6 yrs ago. I will try to find a part number/ manufacturer tomorrow.
[Re: sthemi]
#869319
12/05/10 11:02 AM
12/05/10 11:02 AM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I found a different one. from american innovation corp. couldn't find a website. can't find any contact info though. thought I had it cause there is an american innovatin"S" corp with an s at the end... not the same.. It was shown on some car review website... with no reviews. http://www.carreview.com/mfr/american-innovation-corp/misc-parts/PRD_412350_1599crx.aspxInstead of searching for "glass fuse adapter" I had much better luck with "AGC to ATO fuse adapter"
[Re: Pool Fixer]
#869320
12/05/10 02:24 PM
12/05/10 02:24 PM
Chal340
FRANCE, Paris
Yes, american corp innovation was the dealer where we bought this adapter but now it's closed. The website is closed : http://www.aicorp.us/order/eShopping.htmI sent an email to The best connection JTTproducts and they answered me that they had discontinued this part number.
[Re: Chal340]
#869323
12/07/10 11:51 AM
12/07/10 11:51 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
are you trying to change them for availability in Europe or for another reason ?
availability in Europe, maybe not in car parts stores, but YOU SHOULD BE ABLE TO FIND THEM at electronic shops ( kinda radioshack, or electronic parts shops where you buy integrated circuits, transistors etc... ). LOT OF Electrical devices use the same car units... big glass ones. I know mostly european electrical devices uses small ones, but still lot more use the big glass ones
[Re: NachoRT74]
#869324
12/07/10 05:44 PM
12/07/10 05:44 PM
Chal340
FRANCE, Paris
These glass tube fuses are difficult to change, you can break them by removing from the fuse box and you know it is always in the night or when it's raining that you have to remove it. . So it's easier with this adapter.
[Re: L.R Helbling]
#2246848
02/03/17 10:27 PM
02/03/17 10:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Much cheaper at RockAuto. part numbers CBF10 - 10 amp CBF15 - 15 amp CBF20 - 20 amp CBF30 - 30 amp
[Re: BDW]
#2246882
02/03/17 11:17 PM
02/03/17 11:17 PM
Supercuda
About to go away
About to go away
up yours
Seems like a nice upgrade, but how often do you need to replace a fuse? Depends on how often you are in the bad part of town, at night, with it raining buckets and dead batteries in your flashlight.
[Re: Supercuda]
#2246934
02/04/17 12:24 AM
02/04/17 12:24 AM
Posts: 4,707 Florida
BDW
Seems like a nice upgrade, but how often do you need to replace a fuse? Depends on how often you are in the bad part of town, at night, with it raining buckets and dead batteries in your flashlight. Well if it's night and you don't have a flashlight, your not changing that ATM fuse either..... On a side note, I wonder why they only specify it for GM?
[Re: Chal340]
#2246949
02/04/17 12:59 AM
02/04/17 12:59 AM
Supercuda
About to go away
About to go away
up yours
If you have the ATM fuse that lights up when it blows you could (built in LED).
[Re: MI_Custumz]
#2769371
04/29/20 08:11 AM
04/29/20 08:11 AM
BDW
If you’re constantly changing blown fuses, breaker style. I’d prefer the mini blade adapter, but can’t find those, might be discontinued?
[Re: moparx]
#2769545
04/29/20 04:07 PM
04/29/20 04:07 PM
Posts: 2,915 Calgary, Alberta Canada
a12rag
If you’re constantly changing blown fuses, breaker style. if you are constantly blowing fuses, i would look into just WHY the fuses are constantly blowing, before the "magic smoke" escapes from the harness just before the flames appear ! X2 . . . fuses are in circuit to protect for overload and short circuit . . . typically in our cars, it is usually a short circuit that creates the problem ! (hot wire against ground) . . . fix the problem and don't blame the fuse !
[Re: moparx]
#2769638
04/29/20 08:14 PM
04/29/20 08:14 PM
Posts: 2,070 CA
crackedback
CA
If you’re constantly changing blown fuses, breaker style. if you are constantly blowing fuses, i would look into just WHY the fuses are constantly blowing, before the "magic smoke" escapes from the harness just before the flames appear ! Yep, that's the solution!
[Re: BDW]
#3097610
11/27/22 07:14 PM
11/27/22 07:14 PM
Posts: 2 Michigan
Parbs
The company stopped making the rubber type. I located these. They actually work better and can expand to shorten to different lengths.www.thingsnotable.com [img] http://www.thingsnotable.com[/img]
[Re: BDW]
#3097646
11/27/22 09:27 PM
11/27/22 09:27 PM
Posts: 5,439 So Cal
Sinitro
So Cal
So it's $70 for 12 of these shipped, still wondering why it's needed? I've had my car 20+ years and have NEVER replaced a fuse, or any other car for that matter. Never had to replace fuse.. Consider yourself lucky. The older style glass fuses are harder to find nowadays. Also a glass fuse can actually be open after constant surges as its internal element can fatigue and eventually be open. In our older cars a fuse can blow easily if a hot wire is grounded or even a shorted switch... The later blade fuses are available everywhere, so the Flex Fuse is a kool idea. Note they are cheaper on E-Bay @ $5 each... See below link.. Just my $0.02... https://www.ebay.com/itm/325389527067
[Re: moparx]
#3097822
11/28/22 03:35 PM
11/28/22 03:35 PM
Posts: 5,439 So Cal
Sinitro
So Cal
I updated the posted link.. Thank U... Just my $0.02...
[Re: Sinitro]
#3097851
11/28/22 05:06 PM
11/28/22 05:06 PM
BDW
So EBay is even worse than the website, $20 for 3…..….................... Harbor Freight still sells the "old" fuses, bought a mega pack for <$10 bucks several years ago, And I will admit I did have to use 1, it broke when I was removing to change, when I bought a new harness. 60 for $8 https://www.harborfreight.com/60-piece-agc-glass-automotive-fuse-set-67692.html
[Re: 340SIX]
#3098228
11/29/22 10:52 PM
11/29/22 10:52 PM
Posts: 15,311 Omaha Ne
TJP
Omaha Ne
f. I know few years back Harbor Freight sold some thst were not blowing. The consensus was don't buy them.
Do not know if that is still the same but see plenty bulk type packs of all kinds glass, plastic in bulk on eBay, Amazon etc. I do know I spent a ton on M&H main Harness, Engine Bay, Trans, Forward Light and Rear Light Group Would suck to not pop a fuse and burn the car down. Do all fuses come from the same places now China? Thoughts as I have used up most of my stash on friends cars and working at friends body shop. Covered above
Don't know
I would suggest buying name rand fuses like Bussman, Llittlefuse etc. They can usually be ordered by your local parts store, bendover NAPA OR Try the electronic supply houses like Allied, Arrow, Mouser, Newark, Digi Key etc. as suggested by myself and another PSST! you'll find the supply houses MUCH CHEAPER. One can also shop the bay & AMZ but MAKE SURE you're not getting a knocked up (off) version
