Page 3 of 3 1 2 3
Re: glass tube fuses adaptor [Re: BDW] #3097610
11/27/22 07:14 PM
11/27/22 07:14 PM
P
Parbs Offline
Parbs  Offline
P
The company stopped making the rubber type. I located these. They actually work better and can expand to shorten to different lengths.www.thingsnotable.com
[img]http://www.thingsnotable.com[/img]
Re: glass tube fuses adaptor [Re: Parbs] #3097638
11/27/22 09:08 PM
11/27/22 09:08 PM
BDW Online content
BDW  Online Content
So it's $70 for 12 of these shipped, still wondering why it's needed?
I've had my car 20+ years and have NEVER replaced a fuse, or any other car for that matter.
Re: glass tube fuses adaptor [Re: BDW] #3097646
11/27/22 09:27 PM
11/27/22 09:27 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Never had to replace fuse.. confused
Consider yourself lucky. smile
The older style glass fuses are harder to find nowadays.
Also a glass fuse can actually be open after constant surges as its internal element can fatigue and eventually be open.
In our older cars a fuse can blow easily if a hot wire is grounded or even a shorted switch...
The later blade fuses are available everywhere, so the Flex Fuse is a kool idea.
Note they are cheaper on E-Bay @ $5 each...
See below link..
Just my $0.02... wink
https://www.ebay.com/itm/325389527067
Re: glass tube fuses adaptor [Re: NachoRT74] #3097655
11/27/22 10:38 PM
11/27/22 10:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by NachoRT74
Quote
I would like to buy this kind of adaptor to replace all glass tube fuses, do you know where I could buy them. Thanks
are you trying to change them for availability in Europe or for another reason ?
availability in Europe, maybe not in car parts stores, but YOU SHOULD BE ABLE TO FIND THEM at electronic shops ( kinda radioshack, or electronic parts shops where you buy integrated circuits, transistors etc... ). LOT OF Electrical devices use the same car units... big glass ones. I know mostly european electrical devices uses small ones, but still lot more use the big glass ones
up Should also mention using adapters is adding two more connections in the circuit. Electronics 101a teaches one to avoid added connections whenever possible wink whistling beer
Re: glass tube fuses adaptor [Re: Sinitro] #3097789
11/28/22 02:08 PM
11/28/22 02:08 PM
moparx Offline
moparx  Offline
Re: glass tube fuses adaptor [Re: moparx] #3097822
11/28/22 03:35 PM
11/28/22 03:35 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Originally Posted by moparx
I updated the posted link..
Thank U...
Re: glass tube fuses adaptor [Re: Sinitro] #3097851
11/28/22 05:06 PM
11/28/22 05:06 PM
BDW Online content
BDW  Online Content
So EBay is even worse than the website,
$20 for 3…..…....................
Harbor Freight still sells the "old" fuses, bought a mega pack for <$10 bucks several years ago,
And I will admit I did have to use 1, it broke when I was removing to change, when I bought a new harness.
60 for $8
https://www.harborfreight.com/60-piece-agc-glass-automotive-fuse-set-67692.html
Re: glass tube fuses adaptor [Re: BDW] #3097858
11/28/22 05:22 PM
11/28/22 05:22 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Re: glass tube fuses adaptor [Re: BDW] #3097944
11/28/22 10:23 PM
11/28/22 10:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
60 for $8
just a heads up on "DEAL" glass fuses. Several years back there was a bunch of UHH overseas fuses that were not FUSING at there rated amperage but rather much HIGHER shock and created some unexpected meltdowns. I have bought name brand glass fuses from several sources including Napa and other stores. they may not be in stock but can be ordered. Ebay and AMZ are other sources as well as previously mentioned electronic supply places.
Re: glass tube fuses adaptor [Re: TJP] #3097987
11/29/22 03:11 AM
11/29/22 03:11 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Since we are on.the subject Year's ago I went around the You Pull It and filled both pockets with Glass Fuses. Next trip Did the same with newer style plasic ones regular and mini.
Guy hardly charged me much. Came from.low mile wrecked old car and as new as possible new car for plastic.
I figured known good fuses were better then new China stuff.
I know few years back Harbor Freight sold some thst were not blowing.
The consensus was don't buy them.
Do not know if that is still the same but see plenty bulk type packs of all kinds glass, plastic in bulk on eBay, Amazon etc.
I do know I spent a ton on M&H main Harness, Engine Bay, Trans, Forward Light and Rear Light Group
Would suck to not pop a fuse and burn the car down.
Do all fuses come from the same places now China?
Thoughts as I have used up most of my stash on friends cars and working at friends body shop.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: glass tube fuses adaptor [Re: 340SIX] #3098228
11/29/22 10:52 PM
11/29/22 10:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by 340SIX
f.
Covered above
Don't know shruggy
I would suggest buying name rand fuses like Bussman, Llittlefuse etc. They can usually be ordered by your local parts store, bendover NAPA OR Try the electronic supply houses like Allied, Arrow, Mouser, Newark, Digi Key etc. as suggested by myself and another wink
PSST! you'll find the supply houses MUCH CHEAPER. One can also shop the bay & AMZ but MAKE SURE you're not getting a knocked up (off) version beer
Re: glass tube fuses adaptor [Re: Parbs] #3098273
11/30/22 07:27 AM
11/30/22 07:27 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
with the Flex Fuse adapter the
https://www.amazon.com/Electronic-S...ive+fuse+amp+meter%2Caps%2C92&sr=8-8
Fuse Buddy tool would be more useable on older equipment
Re: glass tube fuses adaptor [Re: 360view] #3098371
11/30/22 01:17 PM
11/30/22 01:17 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
That's cool. I should test my circuits with the DMM clipped in. Not only for over-draw (likely bad grounds) but under-draw which could then use lighter fuses.
Re: glass tube fuses adaptor [Re: Ray S] #3098808
12/01/22 10:59 PM
12/01/22 10:59 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I usually just buy new old stock USA made fuses on ebay. Easier than popping them out in junkyards.
Page 3 of 3 1 2 3
