Page 2 of 3 1 2 3
Re: glass tube fuses adaptor [Re: sthemi] #869321
12/06/10 07:46 AM
12/06/10 07:46 AM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
Not exactly the same,
I bought them at Murray's, which is now O Reilly, about 6 yrs ago.
I will try to find a part number/ manufacturer tomorrow.
Sthemi, did you find the part number or the manufacturer?
70 Challenger, A66, 340 ci
Re: glass tube fuses adaptor [Re: Chal340] #869322
12/07/10 01:01 AM
12/07/10 01:01 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Buss/ little fuse
cbf breaker..
http://www.cooperbussmann.com/6/GlassTubeFuses.html
Re: glass tube fuses adaptor [Re: Chal340] #869323
12/07/10 11:51 AM
12/07/10 11:51 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
I would like to buy this kind of adaptor to replace all glass tube fuses, do you know where I could buy them. Thanks
are you trying to change them for availability in Europe or for another reason ?
availability in Europe, maybe not in car parts stores, but YOU SHOULD BE ABLE TO FIND THEM at electronic shops ( kinda radioshack, or electronic parts shops where you buy integrated circuits, transistors etc... ). LOT OF Electrical devices use the same car units... big glass ones. I know mostly european electrical devices uses small ones, but still lot more use the big glass ones
Re: glass tube fuses adaptor [Re: NachoRT74] #869324
12/07/10 05:44 PM
12/07/10 05:44 PM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
These glass tube fuses are difficult to change, you can break them by removing from the fuse box and you know it is always in the night or when it's raining that you have to remove it. . So it's easier with this adapter.
Re: glass tube fuses adaptor [Re: Chal340] #2246636
02/03/17 05:23 PM
02/03/17 05:23 PM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
Very old post but I found this adapter for blade fuse.
It's very expensive now but easier to change fuse after you put this adapter.
At Jegs :
http://www.jegs.com/i/RestoParts/759/CH30265/10002/-1
or here :
https://www.opgi.com/skylark/CH30265/
[img:center][/img]
Re: glass tube fuses adaptor [Re: Chal340] #2246642
02/03/17 05:30 PM
02/03/17 05:30 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
Re: glass tube fuses adaptor [Re: L.R Helbling] #2246848
02/03/17 10:27 PM
02/03/17 10:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By L.R Helbling
Much cheaper at RockAuto.
part numbers
CBF10 - 10 amp
CBF15 - 15 amp
CBF20 - 20 amp
CBF30 - 30 amp
Don't be the exception.
Re: glass tube fuses adaptor [Re: Chal340] #2246862
02/03/17 10:52 PM
02/03/17 10:52 PM
BDW Online content
BDW  Online Content
Seems like a nice upgrade, but how often do you need to replace a fuse?
Re: glass tube fuses adaptor [Re: BDW] #2246882
02/03/17 11:17 PM
02/03/17 11:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Depends on how often you are in the bad part of town, at night, with it raining buckets and dead batteries in your flashlight. wink
Re: glass tube fuses adaptor [Re: Supercuda] #2246934
02/04/17 12:24 AM
02/04/17 12:24 AM
BDW Online content
BDW  Online Content
Well if it's night and you don't have a flashlight, your not changing that ATM fuse either.....
On a side note, I wonder why they only specify it for GM?
Re: glass tube fuses adaptor [Re: Chal340] #2246949
02/04/17 12:59 AM
02/04/17 12:59 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you have the ATM fuse that lights up when it blows you could (built in LED).
Re: glass tube fuses adaptor [Re: Supercuda] #2769347
04/29/20 05:45 AM
04/29/20 05:45 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
So which would be better, the breaker style or the blade adapter style?
Re: glass tube fuses adaptor [Re: MI_Custumz] #2769371
04/29/20 08:11 AM
04/29/20 08:11 AM
BDW Online content
BDW  Online Content
If you’re constantly changing blown fuses, breaker style.
I’d prefer the mini blade adapter, but can’t find those, might be discontinued?
Re: glass tube fuses adaptor [Re: BDW] #2769378
04/29/20 08:41 AM
04/29/20 08:41 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I bought mine from Original Parts Group, I know Chevy parts! fan
Re: glass tube fuses adaptor [Re: hemirdrnnr] #2769384
04/29/20 09:17 AM
04/29/20 09:17 AM
BDW Online content
BDW  Online Content
Got a link?
Re: glass tube fuses adaptor [Re: BDW] #2769396
04/29/20 10:02 AM
04/29/20 10:02 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Just remember you are still using your "OLD" fuseblock . . . and are adding another "connection" point with the blade style fuses . . . there is nothing wrong with glass fuses . . . what you need is the "magic" spare fuses in the glove box - you have them there, you will NEVER have a fuse go !! LOL . . . once you take them out of the car, LOOK out !!! heh heh heh . . . best solution is to change out the fuseblock panel for blade style fuses, but that is more work and money . . . .
Re: glass tube fuses adaptor [Re: BDW] #2769412
04/29/20 11:00 AM
04/29/20 11:00 AM
moparx Offline
moparx  Offline
if you are constantly blowing fuses, i would look into just WHY the fuses are constantly blowing, before the "magic smoke" escapes from the harness just before the flames appear !
beer
Re: glass tube fuses adaptor [Re: a12rag] #2769423
04/29/20 11:23 AM
04/29/20 11:23 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree Electronics 101A teaches you that every connection is a potential problem. Avoid them when possible beer
Re: glass tube fuses adaptor [Re: moparx] #2769545
04/29/20 04:07 PM
04/29/20 04:07 PM
a12rag Offline
a12rag  Offline
beer
X2 . . . fuses are in circuit to protect for overload and short circuit . . . typically in our cars, it is usually a short circuit that creates the problem ! (hot wire against ground) . . . fix the problem and don't blame the fuse !
Re: glass tube fuses adaptor [Re: moparx] #2769638
04/29/20 08:14 PM
04/29/20 08:14 PM
CA
crackedback Offline
crackedback  Offline
CA
beer
Yep, that's the solution!
Page 2 of 3 1 2 3
