Force Fed Fish.. #866088
11/28/10 11:33 PM
11/28/10 11:33 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Ok folks,
I am sure someone here has seen my build elsewhere!! I need to know how to contact Scott Brown...
I am building a 68 Formula "S" 383 Barracuda. Decided to go Turbo!! I am installing a 80mm B/W S480 with the upgraded 1.10 A/R housing and .83 wheel(quicker spool). My 383 was cracked soooo it now will be a 400 .060 over. It's still in the machine shop. I have almost everything for the install. I need info. on a Scott Brown cam I have and if it is usable for my application. Here are the specs.,
Specs: Intake Exhaust
Lobe Lift .360 .353
Rocker ratio 1.5 1.5
Valve Lift .540 .530
Adv Dur 287 303
[Email]Dur@.50[/Email] 240 252
Lobe CentLin 108 116
Lash Hot .000 .000
Valve timing Open Close
@.50 Int 12 BTDC 48 ABDC
Exh 62 BBDC 10 ATDC
Lobe Seperation 112
Degree Intake Lobe 108
Looks to have good lobe seperation. I just do not know the rpm range!? Does anyone know how to contact Scott Brown???????
Am also looking at the Crower cams 32979 Turbomaster hyd camshaft
Some photos of the Turbo!!
Re: Force Fed Fish.. [Re: CUUDAK] #866089
11/28/10 11:35 PM
11/28/10 11:35 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
One more!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Force Fed Fish.. [Re: CUUDAK] #866090
11/29/10 10:51 PM
11/29/10 10:51 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
is your turbo location device made of nylon or natural fibers ?
home of the
Sox and Martin Hemi Duster
Re: Force Fed Fish.. [Re: HEMIFRED] #866091
11/30/10 12:22 AM
11/30/10 12:22 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I'll tell you right now, you need to block that heat crossover in the intake if you don't want unpredictable fueling problems.
Re: Force Fed Fish.. [Re: TRENDZ] #866092
11/30/10 01:29 AM
11/30/10 01:29 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Yeah,
The engine that is in the pic is a 440 sooooo that p.o.s. Torker2 ain't gonna work. I am using a Performer RPM.
Turbo Location Device
It's Hemp Twine!
Re: Force Fed Fish.. [Re: CUUDAK] #866093
11/30/10 06:24 AM
11/30/10 06:24 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Yeah,
It's Hemp Twine!
great that way you can smoke then competition
the cam looks ok
home of the
Re: Force Fed Fish.. [Re: HEMIFRED] #866094
11/30/10 09:30 AM
11/30/10 09:30 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
PM sent with Scott Brown contact info
Re: Force Fed Fish.. [Re: PHJ426] #866095
12/01/10 03:54 AM
12/01/10 03:54 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Thanks Paul!! He emailed me back right away! Looks like the cam is very good for my setup.
Thanks again,
Robert
Re: Force Fed Fish.. [Re: CUUDAK] #866096
12/01/10 09:58 AM
12/01/10 09:58 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Would it be easier to mount the turbo on the other side of the engine compartment?
Re: Force Fed Fish.. [Re: Defbob] #866097
12/01/10 02:48 PM
12/01/10 02:48 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Robert, no problem I have Scott on speed dial now LOL.
Check out the intake on this thread here in moparts. I have not been able to find a p/n on it and I dont know if they make this for a B block.
Check it out here:
https://board.moparts.org/ubbthreads/show...e=2#Post6242151
Re: Force Fed Fish.. [Re: PHJ426] #866098
12/01/10 03:05 PM
12/01/10 03:05 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Re: Force Fed Fish.. [Re: Defbob] #866099
12/01/10 09:11 PM
12/01/10 09:11 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
That's what I was thinking. I don't have any turbo experience, but I'm curious as to why you would want the air outlet side pointing straight down like that? Are you planning to run an intercooler?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Force Fed Fish.. [Re: DusterDave] #866100
12/01/10 11:44 PM
12/01/10 11:44 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Guys,
I had just recieved the turbo that day and tied it up in the general area where I wanted to place it. The compressor housing was like that to stabilize it for photos. I have since moved it to the passenger side so the 5' downpipe will be considerably shorter. I didn't clock the housings.
I am still waiting on the machine shop to finish preping the 400 block. 440 is in the photos so I cannot mock anything up until I get the right block.
Here is a pic of new location.
Re: Force Fed Fish.. [Re: CUUDAK] #866101
12/01/10 11:48 PM
12/01/10 11:48 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Intercooler pic
Re: Force Fed Fish.. [Re: CUUDAK] #866102
12/02/10 09:16 PM
12/02/10 09:16 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Re: Force Fed Fish.. MySet-up! [Re: CUUDAK] #866103
12/05/10 09:59 PM
12/05/10 09:59 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
I did not elaborate but this is what I have in my set-up.
I don't know if you guys have seen the MadDart build but I Started mine soon after. This was to be a budget build with ebay stuff. My plan was twin Chinese GT45 turbos but could not bring myself to do it that way.
I got the BW S480.
The S480 80mm with upgraded 1.10 A/R housing and .83 wheel is from the clasiffied section in TTF $775.00 shipped, came with 5" V-band clamp and starter pipe and 5" to 4" reducer that I am not using.
Oil feed and return kit from ebay $40 shipped
The JDMSport intercooler is from ebay, nice heavy cast piece. Pressure tested at 30lbs for 2 days. No leaks. The piping and couplers came with the kit for $145.00 plus $50 shipping. I will probably change the couplers later due to them being 3 layer. They look like they will be ok tho.
2- 3" to 4" couplers and 2 4" clamps(Ebay) Don't remember price
Bonnet/hat is a Spectre from ebay at $90 shipped, stud kit from autozone and it too is Spectre.
Godspeed 50mm BOV is from ebay at $68
Godspeed 60mm Wastegate is from ebay at $120 shipped
Hallman BMC is from ebay at $70 shipped
3/8" header flanges from ebay at $38 plus 15 shipping
Ebay header kit(Weld-up) $119.00 plus shipping(JEGS)
OBX T6 flange from ebay $20 shipped
5 OBX 3" flange kits at $30 ea. plus shipping(Ebay)
2- 5" 90's from MadDart $70 shipped
Aeromotive A1000 pump and boost reference regulator $350 from a friend, barely used
Aeromotive 16303 pump controller brand new from ebay $170.00 shipped
3" mandrel u's and straight pipe from local shop $100.00
K&N round filter from ebay $40 shipped
Autometer boost gauge free from my Pops
AEM afr gauge kit from ebay $150 shipped
$100 for 400 block from a friend
440 Source main girdle $275 plus shipping
$396.00 for Eagle H-beam rods shipped from THmotorsports.com
Forged 383 crank, mine
Ported iron 906 heads, mine.
Machine work and pistons-pins-rings-cam bearing, .060 overbore, Unknown $$ at this time. I still haven't got it from the machinist yet.
Fel-Pro gasket set $60 shipped from ebay
Looking for a used Performer RPM now. PENDING!
Scott Brown cam $315.00 shipped
I know there is more that I am forgetting!!
Will be using the 833 4 speed that is in the car. 3.55's in place of the 3.91's in the 8 3/4 now, will get a set of 3.0? soon after.
Still need to get main and rod inserts, they will be Clevite77 hp's, around $160.00
Mopar billet timing set $80
All of this is going into my QQ1 Blue 1968 383 "H" code Formula "S" Fastback Barracuda
Also bought all new rotors-calipers-pads-bearings-seals-hoses to convert it to disc brakes from 10" drum. $331.00
Just ordered all the balljoints, bushings and tie-rods too! $140
Changing the K-frame from sandwich mount to spool type. Had this already!
Then once this is completed I will begin the Body and Paint work. Waiting on AMD to produce some sheetmetal pieces I need that is suppose to be out in early Spring 2011.
