Ok folks,
I am sure someone here has seen my build elsewhere!! I need to know how to contact Scott Brown...
I am building a 68 Formula "S" 383 Barracuda. Decided to go Turbo!! I am installing a 80mm B/W S480 with the upgraded 1.10 A/R housing and .83 wheel(quicker spool). My 383 was cracked soooo it now will be a 400 .060 over. It's still in the machine shop. I have almost everything for the install. I need info. on a Scott Brown cam I have and if it is usable for my application. Here are the specs.,
Specs: Intake Exhaust
Lobe Lift .360 .353
Rocker ratio 1.5 1.5
Valve Lift .540 .530
Adv Dur 287 303
[Email]Dur@.50[/Email] 240 252
Lobe CentLin 108 116
Lash Hot .000 .000
Valve timing Open Close
@.50 Int 12 BTDC 48 ABDC
Exh 62 BBDC 10 ATDC
Lobe Seperation 112
Degree Intake Lobe 108
Looks to have good lobe seperation. I just do not know the rpm range!? Does anyone know how to contact Scott Brown???????
Am also looking at the Crower cams 32979 Turbomaster hyd camshaft
Some photos of the Turbo!!
