Dropped my block off at the machine shop ! #856329
11/17/10 10:17 PM
11/17/10 10:17 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Yes I am getting started on building my new eng for my 63. I will have the machine shop do the final honing on my block along with decking and align boring it. Once I get it back I will start setting my ring gaps and get ready to measure and assemble it. Boy it feels good to get moving on the new eng. Ron
Re: Dropped my block off at the machine shop ! [Re: 383man] #856330
11/17/10 10:18 PM
11/17/10 10:18 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Glad to hear Ron - good luck!
Re: Dropped my block off at the machine shop ! [Re: 383man] #856331
11/17/10 10:41 PM
11/17/10 10:41 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
who got the job
home of the
Sox and Martin Hemi Duster
Re: Dropped my block off at the machine shop ! [Re: 383man] #856332
11/17/10 10:46 PM
11/17/10 10:46 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
For those that dont know or forgot, like me, Whats the New engine combo going to be.? Congrats on getting it started, mike
Re: Dropped my block off at the machine shop ! [Re: HEMIFRED] #856333
11/17/10 10:49 PM
11/17/10 10:49 PM
okla.
sam64 Offline
sam64  Offline
okla.
hope the machine shops there are a quicker than the ones around here.they tell you 2 weeks lucky if you get it back in 2 months.
Re: Dropped my block off at the machine shop ! [Re: Sport440] #856334
11/17/10 10:53 PM
11/17/10 10:53 PM
Hemiroid Offline
Hemiroid  Offline
Ron, lets hear what the whole package is going to be! I love the old b bodies and I'm really looking forward to the upgrades coming to your car. I always liked your ride and can't wait to see it boogie with the new bullet!!
Re: Dropped my block off at the machine shop ! [Re: sam64] #856335
11/17/10 10:59 PM
11/17/10 10:59 PM
Tell me about it!
The machine shop told me 7-8 weeks.
We are on 19 weeks and still waiting.They are all the same.
Re: Dropped my block off at the machine shop ! #856336
11/17/10 11:05 PM
11/17/10 11:05 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Is this the kind of engine that has 8 barrels,425 hp and goes by the name "THE ORANGE MONSTER"?
Re: Dropped my block off at the machine shop ! [Re: scatpacktom] #856337
11/18/10 02:13 AM
11/18/10 02:13 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks for the kind words. Fred I am using JB's machine shop on Philidalphia rd in White Marsh Md. They have always done good work for me. I am just having them do the final cyl honing along with the align bore and decking. Once I get it back I will start to assemble the shortblock. I will be using a 4.15 crank that should give me about 493 cubes. Its 440 Source kit and I will be checking the crank very close. I am using flattop pistons that should come out right around zero deck so I can get good quench with the .039 head gasket. With the CNC Eddy heads I will be using it should come to right about 11.0 comp. I will be getting my CNC'd Eddy RPM heads from Jeff at Modern Performance. I will also be getting a custom grind cam from Dwayne Porter and it will be a solid flat tappet that will make good power and let me run on pump gas keeping my cyl pressure where we want it. I will start off with a single carb but if it runs like I hope I think I will then go to the crossram. I wanted to try a Victor intake but I dont think it will fit under my hood so I might just start with the Holley Street Dominator since I have one. I will go with roller rockers and may go with the Hughes rockers as I like them. I need to get a new set of headers as the Hedman 1-3/4 on it now wont cut it with this eng. If I left anything out just le me know. Ron
Re: Dropped my block off at the machine shop ! [Re: 383man] #856338
11/18/10 03:15 AM
11/18/10 03:15 AM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Wow.....sounds like a great build!
You will have lots of fun with that. Too cool
Curator at Adams County Speed Shop
Re: Dropped my block off at the machine shop ! [Re: 340man4ever] #856339
11/18/10 03:46 AM
11/18/10 03:46 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Sounds great Ron.Only item I might change is the rockers.Consider the Harland Sharps.(pm me for detail)You can squeeze the Victor in there with a low deck block.You will have to use a very short air cleaner element though.
Leave the gun.......take the Cannoli's....Mike
Re: Dropped my block off at the machine shop ! [Re: mike s] #856340
11/18/10 08:41 AM
11/18/10 08:41 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
about time for a name change
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Dropped my block off at the machine shop ! [Re: StripeHOG] #856341
11/18/10 09:33 AM
11/18/10 09:33 AM
tboomer Online work
tboomer  Online Work
Good luck,Ron! I always enjoy reading about a new build!! Keep us posted!!
Re: Dropped my block off at the machine shop ! [Re: tboomer] #856342
11/18/10 10:26 AM
11/18/10 10:26 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Good luck with it
And don't forget the pics
Re: Dropped my block off at the machine shop ! [Re: WILD BILL] #856343
11/18/10 10:42 AM
11/18/10 10:42 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi Ron,
good luck on the build! and take your time!!
Russ
Re: Dropped my block off at the machine shop ! [Re: old_racer] #856344
11/18/10 11:08 AM
11/18/10 11:08 AM
Az
Crizila Offline
Crizila  Offline
Az
Sounds like a good, sound reliable build ( not too exotic ). Might want to have the block checked before automatically line boring it. Many times this proceedure is done unnecessarily. Could save yourself some $ and a loser than necessary timing chain. JMO. Good luck with it. Wish I had my 63 back - every time I see yours
Fastest 300
Re: Dropped my block off at the machine shop ! [Re: mike s] #856345
11/18/10 11:27 AM
11/18/10 11:27 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
One less headache to worry about.
Not sure of the ratio but here's a new setup for sale.
http://akroncanton.craigslist.org/pts/2057535986.html
Re: Dropped my block off at the machine shop ! [Re: KillerBee] #856346
11/18/10 11:44 AM
11/18/10 11:44 AM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
Good luck with it Ron. Sounds like the new motor should make some good steam!!
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
Re: Dropped my block off at the machine shop ! [Re: 383man] #856347
11/18/10 03:33 PM
11/18/10 03:33 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
Been using JB's machine for a long time. They do very good work and get it done when they say they will. Good luck with the new build.
LBSR
Re: Dropped my block off at the machine shop ! [Re: Bill_LBSR] #856348
11/18/10 04:11 PM
11/18/10 04:11 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Congrats on the new build!!!! If Jr dont step up to the plate,he aint got NO CHANCE now!!!!
Whats Ryan upto now??
