Re: Dropped my block off at the machine shop !
[Re: sam64]
#856335
11/17/10 10:59 PM
11/17/10 10:59 PM
hope the machine shops there are a quicker than the ones around here.they tell you 2 weeks lucky if you get it back in 2 months.
Tell me about it! The machine shop told me 7-8 weeks. We are on 19 weeks and still waiting.They are all the same.
[Re: scatpacktom]
#856337
11/18/10 02:13 AM
11/18/10 02:13 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thanks for the kind words. Fred I am using JB's machine shop on Philidalphia rd in White Marsh Md. They have always done good work for me. I am just having them do the final cyl honing along with the align bore and decking. Once I get it back I will start to assemble the shortblock. I will be using a 4.15 crank that should give me about 493 cubes. Its 440 Source kit and I will be checking the crank very close. I am using flattop pistons that should come out right around zero deck so I can get good quench with the .039 head gasket. With the CNC Eddy heads I will be using it should come to right about 11.0 comp. I will be getting my CNC'd Eddy RPM heads from Jeff at Modern Performance. I will also be getting a custom grind cam from Dwayne Porter and it will be a solid flat tappet that will make good power and let me run on pump gas keeping my cyl pressure where we want it. I will start off with a single carb but if it runs like I hope I think I will then go to the crossram. I wanted to try a Victor intake but I dont think it will fit under my hood so I might just start with the Holley Street Dominator since I have one. I will go with roller rockers and may go with the Hughes rockers as I like them. I need to get a new set of headers as the Hedman 1-3/4 on it now wont cut it with this eng. If I left anything out just le me know. Ron
[Re: 340man4ever]
#856339
11/18/10 03:46 AM
11/18/10 03:46 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Sounds great Ron.Only item I might change is the rockers.Consider the Harland Sharps.(pm me for detail)You can squeeze the Victor in there with a low deck block.You will have to use a very short air cleaner element though.
Leave the gun.......take the Cannoli's....Mike
[Re: tboomer]
#856342
11/18/10 10:26 AM
11/18/10 10:26 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Good luck with it
And don't forget the pics
