Removing Vinyl top Glue residue from 73 Chally roof #854124
11/15/10 05:01 AM
11/15/10 05:01 AM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
Any ideas or experience on removing this stuff?
I'm 99% sure I am Not going to put vinyl back on and would like to take it down to bare metal and prep it.
Should I simply sand it off? Just removed the oroginal top and it's very clean, but has dried glue residue.
Buddy sugested Gasoline...
Sanded quarters down with 80 grit paper, If anyone advises sanding over chemicals, what's the roughest grade paper you'd use?
Many thanks.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: Hoof Hearted] #854125
11/15/10 06:32 AM
11/15/10 06:32 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Don't try sanding glue: it's just gets hot/softened & smears. If it's very dry & brittle: try a chisel scrapper or those single-edge retractable metal razor scrappers. If it's still a little pliable a hot gun will soften it enought to srap.
Also 3M scotch-brite discs work many times.
Alot less messy then those spray on adhesive removers.
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: PhillyRag] #854126
11/15/10 10:10 AM
11/15/10 10:10 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
PPG makes a Grease and adhesive remover, DX 330. Use that and some scotch brite pads. works well on undercoating also.
Gary
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: Mr340] #854127
11/15/10 01:00 PM
11/15/10 01:00 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Someone in the restoration projects section used WD-40 to get the glue off of his console top plate after the woodgrain was removed. I don't know if that would desolve the vinyl top glue or not.
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: Hoof Hearted] #854128
11/15/10 01:22 PM
11/15/10 01:22 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Since you're going to go down to metal anyway, use a relatively stiff wire wheel on a drill, take off all the glue (it will put scratches in the paint)and then sand down the paint then prime and seal it. That's the way it worked best for me.
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: 71 Charger R/T] #854129
11/15/10 02:06 PM
11/15/10 02:06 PM
Bel Air Maryland USA 21014
wmwalden Offline
wmwalden  Offline
I used a straight single sided razor-blade. Went right down to bare metal and goes quick.
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: wmwalden] #854130
11/15/10 02:28 PM
11/15/10 02:28 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Goof off or goo gone and a razor blade and about 3 hours to do a 70 dart roof completely.
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: moparpollack] #854131
11/15/10 02:54 PM
11/15/10 02:54 PM
IMGTX Offline
IMGTX  Offline
I used that for my car. It even took some of the paint off under the glue.
You can buy it just about anywhere.
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: moparpollack] #854132
11/15/10 02:58 PM
11/15/10 02:58 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
I soak up some paper towels in goo be gone or such. Lay them on the roof for a few hours. Then the glue just comes off with a paper towel. I usually let it sit overnight.
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: Devil] #854133
11/15/10 03:27 PM
11/15/10 03:27 PM
S.E. Conn
S.E. Conn
Genius!
Will try it.
2005 300C Hemi
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: Devil] #854134
11/15/10 03:38 PM
11/15/10 03:38 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Excellent tip, I've been using the 3M discs with excellent results until as mentioned above it warms up and gets all gooey. Think I'll try Goo be Gone for the remainder.
Re: Removing Vinyl top Glue residue from 73 Chally roof [Re: Hoof Hearted] #854135
11/15/10 07:27 PM
11/15/10 07:27 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I used a razor blade in a scraper with Goof Off as a lubricant/softener. The fumes make you crazy. Makes you order some more parts.
Craig
