Removing Vinyl top Glue residue from 73 Chally roof
#854124
11/15/10 05:01 AM
11/15/10 05:01 AM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Any ideas or experience on removing this stuff? I'm 99% sure I am Not going to put vinyl back on and would like to take it down to bare metal and prep it. Should I simply sand it off? Just removed the oroginal top and it's very clean, but has dried glue residue. Buddy sugested Gasoline... Sanded quarters down with 80 grit paper, If anyone advises sanding over chemicals, what's the roughest grade paper you'd use? Many thanks.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Removing Vinyl top Glue residue from 73 Chally roof
[Re: wmwalden]
#854130
11/15/10 02:28 PM
11/15/10 02:28 PM
moparpollack
Lil Herman
Lil Herman
85086
Goof off or goo gone and a razor blade and about 3 hours to do a 70 dart roof completely.
[Re: moparpollack]
#854131
11/15/10 02:54 PM
11/15/10 02:54 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I used that for my car. It even took some of the paint off under the glue.
You can buy it just about anywhere.
[Re: Hoof Hearted]
#854135
11/15/10 07:27 PM
11/15/10 07:27 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I used a razor blade in a scraper with Goof Off as a lubricant/softener. The fumes make you crazy. Makes you order some more parts. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
