Aluminum water pump housing mod #853493
11/14/10 05:46 PM
11/14/10 05:46 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have an aluminum waterpump housing that is off of an original 1965 A990 car. If you look down through the thermostat hole there are two areas I guess would be the way to say it. In the back section which would be the block side there is a hole drilled and tapped with a pipe plug in it with a 1/8 hole drilled in it.
What is the purpose of this?
It is creating a hole that allows coolant to do what?
Re: Aluminum water pump housing mod [Re: maxie] #853494
11/14/10 06:12 PM
11/14/10 06:12 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
I would not mod or cut-up a A990 WP. I say SELL IT and just buy a repop and use that.
Re: Aluminum water pump housing mod [Re: dOOc] #853495
11/14/10 06:16 PM
11/14/10 06:16 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Sox and Martin Hemi Duster
Re: Aluminum water pump housing mod [Re: HEMIFRED] #853496
11/14/10 06:17 PM
11/14/10 06:17 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
If you read the post it states that is already modified. Was that way when I got it.
Re: Aluminum water pump housing mod [Re: maxie] #853497
11/14/10 09:01 PM
11/14/10 09:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
Those holes are to allow coolant to circulate when the thermostat is closed, I think I drill two 1/8 holes in my thermostats also for that very same reason, let the air out so I can fill the cooling system up completely without having to wait for the thermostst to open and it lets a small amount of coolant to circulate while warming up
Re: Aluminum water pump housing mod [Re: Cab_Burge] #853498
11/14/10 09:10 PM
11/14/10 09:10 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
So more than likely they drilled a hole way to big and the car never warmed up and put a plug in it with a 1/8 hole in it. So the car would warm up.
Re: Aluminum water pump housing mod [Re: maxie] #853499
11/14/10 10:09 PM
11/14/10 10:09 PM
CrazyD Offline
CrazyD  Offline
the brass pipe plug prevents coolant from recirculating thru the block - it forces all coolant thru the rad. Common to cars running with no t-stat.
Re: Aluminum water pump housing mod [Re: maxie] #853500
11/15/10 10:27 PM
11/15/10 10:27 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Some coolant needs to flow though the block when the T-stat is closed so that the water heated in the engine can get to the T-stat and open it. The plug with smaller hole is just to minimize the flow that short-circuits the radiator.
