Mini starter question. #848969
11/08/10 03:12 PM
11/08/10 03:12 PM
Murrayville, Illinois, usa
scotts66charger Offline OP
I have an older mini starter( aprox 10/11 years old).Everyonce in a while, after going to town to cruz around, I will go to 'sonic' for a burger. After the burger, I try and start the car,but it wont start. I tried an old trick from high school, by touching a wrench across the starter and bendix, shorting it out, and starting the car. It didnt do it all the time ( about every 2/3 weeks). Now the car wont start except you put the wrench across the starter like posted above. Question is, Do you guys think the 'Bendix' is bad,or something ? Any help would be Great. Thank you in advance. scott
Re: Mini starter question. [Re: scotts66charger] #848970
11/08/10 03:19 PM
11/08/10 03:19 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Will it start if you do the same at the relay?
Re: Mini starter question. [Re: pushbutton] #848971
11/08/10 04:13 PM
11/08/10 04:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Only difference is that it is done at the opposite end of the wire, so unless there is a bad wire it should start by jumping the relay terminals.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Mini starter question. [Re: MoparforLife] #848972
11/08/10 04:20 PM
11/08/10 04:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it's an automatic move the shifter through the gears while holding the key in the start position. Sometimes the shift linkage will slip just a little and cause this problem.
Re: Mini starter question. [Re: scotts66charger] #848973
11/09/10 02:40 AM
11/09/10 02:40 AM
RoadRaceDart Offline
If shorting the terminals at the starter works then you just proved its not the starter at fault. I would check the neutral safety switch first if you have one then the starter relay and wiring.
Joshua
Re: Mini starter question. [Re: RoadRaceDart] #848974
11/09/10 02:06 PM
11/09/10 02:06 PM
Thanx guys, I will try all that !!! Its good to get info from others who have had this same problem.. Also to Mr. Skinner, I see you live in portland Oregon. I lived in Bend oregon for Years, and Eugene. M y daughter lives in portland now. small world. thanx again all......
Re: Mini starter question. [Re: pushbutton] #848975
11/10/10 02:13 AM
11/10/10 02:13 AM
Where is the relay on a 66 charger?
Re: Mini starter question. [Re: scotts66charger] #848976
11/10/10 12:13 PM
11/10/10 12:13 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Firewall left side,follow the wires up from the starter.
