Mini starter question.
#848969
11/08/10 03:12 PM
11/08/10 03:12 PM
Posts: 188 Murrayville, Illinois, usa
scotts66charger
I have an older mini starter( aprox 10/11 years old).Everyonce in a while, after going to town to cruz around, I will go to 'sonic' for a burger. After the burger, I try and start the car,but it wont start. I tried an old trick from high school, by touching a wrench across the starter and bendix, shorting it out, and starting the car. It didnt do it all the time ( about every 2/3 weeks). Now the car wont start except you put the wrench across the starter like posted above. Question is, Do you guys think the 'Bendix' is bad,or something ? Any help would be Great. Thank you in advance. scott
Re: Mini starter question.
[Re: scotts66charger]
#848973
11/09/10 02:40 AM
11/09/10 02:40 AM
Posts: 101 Oregon
RoadRaceDart
If shorting the terminals at the starter works then you just proved its not the starter at fault. I would check the neutral safety switch first if you have one then the starter relay and wiring.
Joshua
#848976
11/10/10 12:13 PM
11/10/10 12:13 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Where is the relay on a 66 charger?
Firewall left side,follow the wires up from the starter.
