Next step, EZ heads #835176
10/21/10 08:54 AM
10/21/10 08:54 AM
Illinois
Mopar_Ray Offline OP
Illinois
I am looking at Indy EZ heads. Motor is a 440/505 stroker, TTI 2-1/8 step headers, Comp XE295HL Hydraulic, 251/257 duration, 564/564 lift cam. I want to stick with my current cam for now. So I'm wondering which EZ's to go with, standard port or max-wedge port?
Re: Next step, EZ heads [Re: Mopar_Ray] #835177
10/21/10 09:04 AM
10/21/10 09:04 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
You may have issues fitting the tti step headers as they are for a raised exhaust port head?
Re: Next step, EZ heads [Re: ToddP] #835178
10/21/10 09:11 AM
10/21/10 09:11 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
EZs use all standard Mopar parts.The port will depend on how much power and at what RPM.
Re: Next step, EZ heads [Re: ToddP] #835179
10/21/10 09:12 AM
10/21/10 09:12 AM
Illinois
Illinois
They are custom low deck headers, modified by TTI to work on a 440 with standard exhaust port location. Fit fine on stock heads, but are meant to work with heads with angled plugs. They don't play nice with straight plugs.
Re: Next step, EZ heads [Re: Mopar_Ray] #835180
10/21/10 09:23 AM
10/21/10 09:23 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I kindof use both. i bought the bottom of the line EZs from Porter who touched up the guides, angles and a backcut on the valves. i ported the heads out to MW but i use a standard port intake that has been welded up at the flange to make it fit MW. i ported the intake alot to make the runners as large as possible though
Re: Next step, EZ heads [Re: B G Racing] #835181
10/21/10 09:24 AM
10/21/10 09:24 AM
Illinois
Illinois
I'm looking for about 750 hp eventually. I don't think I'm gonna get there with this cam. Trying to figure out which will work best with my current cam?
Re: Next step, EZ heads [Re: Mopar_Ray] #835182
10/21/10 09:37 AM
10/21/10 09:37 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Max wedge ports ,more compression and big cam. You can always start with the standard port then upgrade later.
Re: Next step, EZ heads [Re: B G Racing] #835183
10/21/10 09:51 AM
10/21/10 09:51 AM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
If you stay with EZ heads, it would be best to start out with the EZ-1 kit. The EZ-1 heads have the Max Wedge ports to start with and are only a couple hundred dollars more. I'm sure it would cost at least that to open a set of standard EZ heads up to MW port size anyway. Exhaust ports are still the same, so no special headers are required with the EZ-1.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Next step, EZ heads [Re: maundmotorworks] #835184
10/21/10 09:57 AM
10/21/10 09:57 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Matt has done a lot of EZ builds.
Re: Next step, EZ heads [Re: Mopar_Ray] #835185
10/21/10 11:50 AM
10/21/10 11:50 AM
AndyF Offline
AndyF  Offline
I've spent a lot of time with a EZ headed 505 on the dyno. A lot of what I've learned is in the tech archives.
Re: Next step, EZ heads [Re: Mopar_Ray] #835186
10/21/10 11:56 AM
10/21/10 11:56 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
"I'm looking for about 750 hp eventually"
You may be better off to go with the "traditional" -1's.
I ran them with a 498, 12:1 compression, .640, 259 @ .050 solid roller. I never did dyno it but it did run 9.87 @ 137 in a 3500 lb street car set up for nitrous (4.30 gear/30" tire, tight 4000 converter, footbrake). Based on that, I am guessing I made 720ish hp.
Re: Next step, EZ heads [Re: TheOtherDodge] #835187
10/21/10 12:26 PM
10/21/10 12:26 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Or a set of Big Easys
Re: Next step, EZ heads [Re: maundmotorworks] #835188
10/21/10 02:12 PM
10/21/10 02:12 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I agree X2
Re: Next step, EZ heads [Re: 70blackfish] #835189
10/21/10 02:15 PM
10/21/10 02:15 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
and I would p/u Andys book...you will be glad you did.
Re: Next step, EZ heads [Re: 70blackfish] #835190
10/21/10 02:34 PM
10/21/10 02:34 PM
AndyF Offline
AndyF  Offline
I did include a fair amount of EZ related stuff in the book including the Jesel conversion. I don't think anyone else has ever published that info. I think the Jesel setup is great for the EZ heads but Indy doesn't sell the kit and neither does Jesel.
The 514 I have on the dyno right now uses my old EZ heads and it is making something north of 800 hp. We broke the dyno load cell during testing so I'm not sure exactly how much power it is making but I can tell it is healthy.
Re: Next step, EZ heads [Re: Mopar_Ray] #835191
10/21/10 06:20 PM
10/21/10 06:20 PM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
With EZ-1's and a nice Indy SP intake - you'll be around 650 HP / 650 lb-ft.
While Std. Port Heads would be fine (especially with that cam) with a future goal of 750 HP will be extremely tough w/o a MW head.
My stroker w/ same cam made #'s in my sig...nice hydraulic cam for us lazy guys that don't feel like lashing valves
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: Next step, EZ heads [Re: Mills] #835192
10/21/10 09:11 PM
10/21/10 09:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have the standard base EZ's with just some bowl work and std.RB ports and it runs great
I am only running a small flat solid cam,Comp 588 XTQ series and it seems perfect with the smaller ports.
There is plenty of potential in the base EZ's with a stock size port
Gus
64 Plymouth Savoy
Dana 60
Re: Next step, EZ heads [Re: fourgearsavoy] #835193
10/21/10 10:05 PM
10/21/10 10:05 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If your after 750hp, go ahead and CNC port the heads now. Im going to say a cam swap will be in order later too. Best to have the heads done right now, than pull the heads later, box them up and ship them out and wait 2 months.
But realistically your current engine will run fine with the OOTB and nicely prep'd EZ heads.
They are much better OOTB than the traditional -1's
