Re: Next step, EZ heads
[Re: ToddP]
#835179
10/21/10 09:12 AM
10/21/10 09:12 AM
Posts: 512 Illinois
Mopar_Ray
Illinois
You may have issues fitting the tti step headers as they are for a raised exhaust port head?
They are custom low deck headers, modified by TTI to work on a 440 with standard exhaust port location. Fit fine on stock heads, but are meant to work with heads with angled plugs. They don't play nice with straight plugs.
[Re: Mopar_Ray]
#835180
10/21/10 09:23 AM
10/21/10 09:23 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I am looking at Indy EZ heads. Motor is a 440/505 stroker, TTI 2-1/8 step headers, Comp XE295HL Hydraulic, 251/257 duration, 564/564 lift cam. I want to stick with my current cam for now. So I'm wondering which EZ's to go with, standard port or max-wedge port?
I kindof use both. i bought the bottom of the line EZs from Porter who touched up the guides, angles and a backcut on the valves. i ported the heads out to MW but i use a standard port intake that has been welded up at the flange to make it fit MW. i ported the intake alot to make the runners as large as possible though
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: B G Racing]
#835181
10/21/10 09:24 AM
10/21/10 09:24 AM
Posts: 512 Illinois
Mopar_Ray
Illinois
EZs use all standard Mopar parts.The port will depend on how much power and at what RPM.
I'm looking for about 750 hp eventually. I don't think I'm gonna get there with this cam. Trying to figure out which will work best with my current cam?
[Re: Mopar_Ray]
#835182
10/21/10 09:37 AM
10/21/10 09:37 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Max wedge ports ,more compression and big cam. You can always start with the standard port then upgrade later. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: B G Racing]
#835183
10/21/10 09:51 AM
10/21/10 09:51 AM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
If you stay with EZ heads, it would be best to start out with the EZ-1 kit. The EZ-1 heads have the Max Wedge ports to start with and are only a couple hundred dollars more. I'm sure it would cost at least that to open a set of standard EZ heads up to MW port size anyway. Exhaust ports are still the same, so no special headers are required with the EZ-1.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
[Re: maundmotorworks]
#835184
10/21/10 09:57 AM
10/21/10 09:57 AM
B G Racing
Eighty Four, PA
Matt has done a lot of EZ builds. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Mopar_Ray]
#835186
10/21/10 11:56 AM
10/21/10 11:56 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
"I'm looking for about 750 hp eventually" You may be better off to go with the "traditional" -1's. ![](/ubbthreads/images/graemlins/Twocents.gif) I ran them with a 498, 12:1 compression, .640, 259 @ .050 solid roller. I never did dyno it but it did run 9.87 @ 137 in a 3500 lb street car set up for nitrous (4.30 gear/30" tire, tight 4000 converter, footbrake). Based on that, I am guessing I made 720ish hp.
[Re: TheOtherDodge]
#835187
10/21/10 12:26 PM
10/21/10 12:26 PM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
Or a set of Big Easys
#835188
10/21/10 02:12 PM
10/21/10 02:12 PM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
I agree X2
[Re: Mopar_Ray]
#835191
10/21/10 06:20 PM
10/21/10 06:20 PM
Posts: 1,379 Airdrie, AB
Mills
Airdrie, AB
With EZ-1's and a nice Indy SP intake - you'll be around 650 HP / 650 lb-ft.
While Std. Port Heads would be fine (especially with that cam) with a future goal of 750 HP will be extremely tough w/o a MW head.
My stroker w/ same cam made #'s in my sig...nice hydraulic cam for us lazy guys that don't feel like lashing valves ![](/ubbthreads/images/graemlins/laugh2.gif)
1967 Satellite, CNC Eddy Headed 500ci Street Mauler (Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell 2012 Hemi Ram Sport Crew Cab 2011 Avenger, Pentastar V-6 2007 SRT-8 Charger (Dyno'ed @ 470 RWHP) 1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
[Re: Mills]
#835192
10/21/10 09:11 PM
10/21/10 09:11 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have the standard base EZ's with just some bowl work and std.RB ports and it runs great ![](/ubbthreads/images/graemlins/thumbs.gif) I am only running a small flat solid cam,Comp 588 XTQ series and it seems perfect with the smaller ports. There is plenty of potential in the base EZ's with a stock size port ![](/ubbthreads/images/graemlins/Twocents.gif) Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#835193
10/21/10 10:05 PM
10/21/10 10:05 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
If your after 750hp, go ahead and CNC port the heads now. Im going to say a cam swap will be in order later too. Best to have the heads done right now, than pull the heads later, box them up and ship them out and wait 2 months. ![](/ubbthreads/images/graemlins/Twocents.gif) But realistically your current engine will run fine with the OOTB and nicely prep'd EZ heads. They are much better OOTB than the traditional -1's
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
