Re: Hone the cam bearing bores?
[Re: dart_73_br]
#815824
09/27/10 05:13 PM
09/27/10 05:13 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Mopar is famous for not getting the cam bores the correct I.D. I have scraped many cam bearings, one at a time, to get the cams to install properly. If you don't have a cam bearing tool take the block to someone who does and remove all of them but the rear one, install the cam in it annd see if it will rotae easily or not. If not look at the tight spots, they shine and scrape the shine off with a BEARING KNIFE, do not try to hone it Once that is fixed mmove to the next one, do one at a time until there all done One of the machine shops that I use to used in SO CA used a brake hone to hone the block cam holes(journals to the proper size and then install new standard cam bearings. I don't live close to them anymore so I have to do it myself (scrape method) now EDITED for content, sorry for rushing earlier IHTMSN
[Re: sshemi]
#815827
09/27/10 07:33 PM
09/27/10 07:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a fix to this problem that i have tried on several motors.
Take an old cam and cut (i did it with an anglegrinder with cutoff wheel) grooves on every bearing journal along the cam. this will make it cut the bearings. use some fine sandpaper to smooth the journals. install cam with oil and turn a few turns. I promise it will work.
This is all I do.... I cut a old cam for this purpose
[Re: dart_73_br]
#815830
09/27/10 10:56 PM
09/27/10 10:56 PM
MR_P_BODY
Ok, is like a groove in the middle of the cam journals?
I cut a groove in each cam journal... I used a .040 thick cut off wheel... slip it in and give it a few turns
[Re: MR_P_BODY]
#815831
09/27/10 10:58 PM
09/27/10 10:58 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
dont you have to worry about peeling off a whole layer or making it thin?
[Re: blownzoom440]
#815832
09/27/10 11:35 PM
09/27/10 11:35 PM
MR_P_BODY
Nope it just cuts any tight spots... being that its a full cam its in there straight... and I've never had a cam bearing problem doing it this way
[Re: MR_P_BODY]
#815835
10/02/10 08:17 PM
10/02/10 08:17 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
It's called a "cutter cam" and many machine shops have been doing it this way for years. Is it the "absolute" right way to do it, not really, but the "right" way generally gets to be expensive and not really neded in 90% of applications.
Monte
[Re: Crizila]
#815837
10/03/10 12:06 AM
10/03/10 12:06 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Monte
A quality machine shop will do this automatically as part of the cam bearing install proceedure.
Its the way I do it in my garage!
I guess now, it Qualifies as a Quality Machine shop. mike
