Re: Lifters won't spin..440
[Re: SILVER67]
#813040
09/23/10 11:41 PM
09/23/10 11:41 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Call me at the shop Saturday, and stop over and grab a couple of my Crower lifters....try them. Since you already have swapped some lifters, not sure its going to help, but try another manufacter first.Since its the same bores that its doing it on, I am suspect there, but try these first to save the next step.Bring your two bad lifters, I want to look/measure them.
RIP Monte Smith
[Re: SILVER67]
#813041
09/23/10 11:42 PM
09/23/10 11:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yea lifter face seems okay. Spin freely in the bores too. I haven't measure them though. Is that okay to keep mixing them around until I get them all to spin?
Michael
Fine if its a new cam and lifters
[Re: SILVER67]
#813042
09/23/10 11:48 PM
09/23/10 11:48 PM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
Michael
How much spring pressure do you have ?
[Re: Twostick]
#813046
09/24/10 12:39 AM
09/24/10 12:39 AM
Posts: 784 Liverpool, NY
SILVER67
Liverpool, NY
I believe the tag on the Mopar box said the Cam and Lifters are from 2003....... Pretty sure I bought it in 2004 I'd be tickled pink if I just got some bad lifters. Beats having a bad lifter bore I would think ! Michael
[Re: HEMIFRED]
#813048
09/24/10 01:44 AM
09/24/10 01:44 AM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Thanx Fred I'm pretty sure I saw that on here a few years ago. I can remember stuff like that but I can't find my car keys. IMHO this why 90+% of flat tappet cams fail. Lifters no spin for what ever reason. Kevin
[Re: Twostick]
#813049
09/24/10 03:17 AM
09/24/10 03:17 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I think if you placed the lifters face to face you would not be able to see the crown. good lifters always have the edges show light. the NASCAR guys have a mahcine that puts the crown back and polishes the lifter face
home of the Sox and Martin Hemi Duster
[Re: SILVER67]
#813050
09/24/10 04:30 AM
09/24/10 04:30 AM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
first try very worn old used lifter,any type. if still binds its ovaled/worn/funky lifter bore,hate to say it but, ive honed lifter bores in car complete runing motor intake off with drill motor and wheel cylinder hone. after pull pan plug 1 can brake clean, then flushed with 5 quarts new oil, they will spin like a champ then
MOPAR OR NO CAR
[Re: HEMIFRED]
#813052
09/24/10 08:10 AM
09/24/10 08:10 AM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Sometimes it is too fine of a finish on the lifter base. Take some 500 grit sand paper, put it in the palm of your hand and push the base of the offending lifter into it, rotating the lifter to take the shine off. Clean, reinstall and check again. Works great, I,ve had no failures doing this.
